Salta al contenuto principale
Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement
Cosa ti serve
  1. Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement, Battery: passo 1, immagine 1 di 3 Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement, Battery: passo 1, immagine 2 di 3 Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement, Battery: passo 1, immagine 3 di 3
    • Remove the four 5 mm screws in the right using a Phillips #00 screwdriver.
    • Remove the speaker panel to reveal the battery.
  2. Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement: passo 2, immagine 1 di 2 Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement: passo 2, immagine 2 di 2
    • Unplug the battery with tweezers
  3. Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement: passo 3, immagine 1 di 3 Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement: passo 3, immagine 2 di 3 Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement: passo 3, immagine 3 di 3
    • Gently remove the battery from the device using the plastic spudger.
  4. Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement, Volume & Noise Cancelling Control Button: passo 4, immagine 1 di 3 Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement, Volume & Noise Cancelling Control Button: passo 4, immagine 2 di 3 Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement, Volume & Noise Cancelling Control Button: passo 4, immagine 3 di 3
    • Unscrew the two 3 mm screws retaining the circuit board to the headphones.
    • Carefully remove the circuit board with the plastic prying tool.
  5. Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement: passo 5, immagine 1 di 3 Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement: passo 5, immagine 2 di 3 Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement: passo 5, immagine 3 di 3
    • Next, use the prying tool to remove the buttons.
  6. Sony WH-CH720N Volume & Noise Cancelling Control Button Replacement: passo 6, immagine 1 di 1
    • Remove buttons and replace.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 23
Tutti i Tempi: 79
