Salta al contenuto principale
Sony WH-CH720N Charging Port Replacement
Cosa ti serve
  1. Sony WH-CH720N Charging Port Replacement, Earmuff: passo 1, immagine 1 di 1
    • Place the headphones down on a table, and orient them in this way.
  2. Sony WH-CH720N Charging Port Replacement: passo 2, immagine 1 di 3 Sony WH-CH720N Charging Port Replacement: passo 2, immagine 2 di 3 Sony WH-CH720N Charging Port Replacement: passo 2, immagine 3 di 3
    • Remove the earmuff.
    • Check introductions to ensure you remove the correct side earmuff for each repair guide!
  3. Sony WH-CH720N Charging Port Replacement, Charging Port: passo 3, immagine 1 di 2 Sony WH-CH720N Charging Port Replacement, Charging Port: passo 3, immagine 2 di 2
    • Use a Philips #00 screwdriver to remove the four 5 mm screws from the left driver housing.
  4. Sony WH-CH720N Charging Port Replacement: passo 4, immagine 1 di 3 Sony WH-CH720N Charging Port Replacement: passo 4, immagine 2 di 3 Sony WH-CH720N Charging Port Replacement: passo 4, immagine 3 di 3
    • Using the same bit, remove the two 3 mm screws from the circuit board.
    • Gently remove the circuit board.
  5. Sony WH-CH720N Charging Port Replacement: passo 5, immagine 1 di 1
    • Desolder the four joints holding the USB-C charging port there.
    • Pull the charging port off.
    • Solder the new charging port onto the board.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 23
Tutti i Tempi: 63
