Salta al contenuto principale
Sony WH-1000XM4 Touch Sensor Replacement
Cosa ti serve
  1. Sony WH-1000XM4 Touch Sensor Replacement, Touch Sensor: passo 1, immagine 1 di 1
    • Before beginning any repairs, press and hold the power button on the left ear cup for about 2 seconds until the blue light turns off.
    • Place your headphones onto a work surface, ear pads facing up.
  2. Sony WH-1000XM4 Touch Sensor Replacement: passo 2, immagine 1 di 1
    • Use your thumb to depress the RIGHT ear pad near the long outer edge, creating a gap between the cushion and the frame.
    • Insert the flat end of a spudger into the gap you've created, between the edge of the cushion and the frame.
    • Pivot the spudger down to unclip the long edge of the ear pad.
    • Repeat around perimeter of ear pad until it is loose.
    • When the first clip disconnects, you'll hear an audible clicking sound.
    • This may take a considerable amount of force. If the cushion won't click out of place, move your spudger to different points along the long edge.
  3. Sony WH-1000XM4 Touch Sensor Replacement: passo 3, immagine 1 di 1
    • Remove the right ear pad.
  4. Sony WH-1000XM4 Touch Sensor Replacement: passo 4, immagine 1 di 1
    • Remove the foam liner from the right ear cup's speaker.
  5. Sony WH-1000XM4 Touch Sensor Replacement: passo 5, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the four 8.4 mm screws securing the right ear cup cover.
  6. Sony WH-1000XM4 Touch Sensor Replacement: passo 6, immagine 1 di 1
    • Flip the headphones over, ear cups facing down.
    • Use your fingers to lift up and flip over the right ear cup cover.
    • Don't try to completely remove the cover just yet—it's still attached with the touch cable.
  7. Sony WH-1000XM4 Touch Sensor Replacement: passo 7, immagine 1 di 1
    • Grip the touch ribbon cable and pull it straight out of its connector on the main board to remove it.
    • Remove the ear cup cover with the touch sensor attached.
    • The green touch sensor circuit board is glued to the ear cup cover.
    • Repeat steps in reverse order to reassemble after replacing the touch sensor.
Conclusione
IUPUI, Team 2-1, Harley Fall 2023 Membro di IUPUI, Team 2-1, Harley Fall 2023
IUPUI-HARLEY-F23S2G1
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 177
Tutti i Tempi: 860
