Salta al contenuto principale
Sony WH-1000XM4 Motherboard Replacement
Cosa ti serve
  1. Sony WH-1000XM4 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Before beginning any repairs, press and hold the power button on the left ear cup for about 2 seconds until the blue light turns off.
    • Place your headphones onto a work surface, ear pads facing up.
  2. Sony WH-1000XM4 Motherboard Replacement: passo 2, immagine 1 di 1
    • Use your thumb to depress the LEFT ear pad near the long outer edge, creating a gap between the cushion and the frame.
    • Pivot the spudger down to unclip the long edge of the ear pad.
    • Repeat around the perimeter of the ear pad until it is loose.
    • When the first clip disconnects, you'll hear an audible clicking sound.
    • This may take a considerable amount of force. If the cushion won't click out of place, move your spudger to different points along the long edge.
  3. Sony WH-1000XM4 Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove the left ear pad.
  4. Sony WH-1000XM4 Motherboard Replacement: passo 4, immagine 1 di 1
    • Remove the foam liner from the left ear cup's speaker.
  5. Sony WH-1000XM4 Motherboard Replacement: passo 5, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the four 8.4 mm screws securing the left ear cup cover.
  6. Sony WH-1000XM4 Motherboard Replacement: passo 6, immagine 1 di 1
    • Flip the headphones over, ear cups facing down.
    • Use your fingers to lift up and flip over the left ear cup cover.
    • Don't try to completely remove the cover just yet—it's still attached with many cables.
  7. Sony WH-1000XM4 Motherboard Replacement: passo 7, immagine 1 di 1
    • Unscrew the 4 screws in the corners of the motherboard to loosen it from the left ear cup assembly.
  8. Sony WH-1000XM4 Motherboard Replacement: passo 8, immagine 1 di 1
    • Carefully remove the cable ribbon from the bottom of the motherboard.
  9. Sony WH-1000XM4 Motherboard Replacement: passo 9, immagine 1 di 1
    • Carefully remove the multipin connector (multiple colorful wires) from the side of the motherboard.
  10. Sony WH-1000XM4 Motherboard Replacement: passo 10, immagine 1 di 1
    • Carefully lift the motherboard out from the ear cup to access the other cable ribbons and connectors.
  11. Sony WH-1000XM4 Motherboard Replacement: passo 11, immagine 1 di 1
    • Remove wires from the side or bottom of the motherboard that are attached by pin connectors.
  12. Sony WH-1000XM4 Motherboard Replacement: passo 12, immagine 1 di 1
    • Desolder the remaining wires that are attached to the motherboard.
    • Repeat steps in reverse order to reassemble the headphones after seating the new motherboard.
    • Reference the Service Manual on the Sony WH-1000XM4 main page on the IFixIt website to verify correct wire connections.
Conclusione
IUPUI, Team 2-1, Harley Fall 2023 Membro di IUPUI, Team 2-1, Harley Fall 2023
IUPUI-HARLEY-F23S2G1
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 13
Ultimi 7 Giorni: 68
Ultimi 30 Giorni: 277
Tutti i Tempi: 1,959
