Introduzione
In this guide, you will learn how to remove and replace the RAM Memory Chips from your laptop. If you have this exact laptop, follow the below steps. If you have another laptop, that is still okay, these steps will give you a basic understanding on how to remove the RAM Memory Chips and you can adapt them to your own computer.
Cosa ti serve
Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
Loosen but do not remove the screw over RAM cover panel.
With the screw loosened but not removed, lift up and remove the panel.
