Salta al contenuto principale
Sony Vaio VPCW21FX Keyboard Replacement
Cosa ti serve
  1. Sony Vaio VPCW21FX Keyboard Replacement, Battery: passo 1, immagine 1 di 3 Sony Vaio VPCW21FX Keyboard Replacement, Battery: passo 1, immagine 2 di 3 Sony Vaio VPCW21FX Keyboard Replacement, Battery: passo 1, immagine 3 di 3
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Sony Vaio VPCW21FX Keyboard Replacement: passo 2, immagine 1 di 3 Sony Vaio VPCW21FX Keyboard Replacement: passo 2, immagine 2 di 3 Sony Vaio VPCW21FX Keyboard Replacement: passo 2, immagine 3 di 3
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
  3. Sony Vaio VPCW21FX Keyboard Replacement, Keyboard: passo 3, immagine 1 di 3 Sony Vaio VPCW21FX Keyboard Replacement, Keyboard: passo 3, immagine 2 di 3 Sony Vaio VPCW21FX Keyboard Replacement, Keyboard: passo 3, immagine 3 di 3
    • Open the Lid of the laptop
    • Then using they pry tool to carefully remove the plastic cover around the keyboard
    • It helps to pry from one of the larger keys as they have more room to fit the tool in
  4. Sony Vaio VPCW21FX Keyboard Replacement: passo 4, immagine 1 di 3 Sony Vaio VPCW21FX Keyboard Replacement: passo 4, immagine 2 di 3 Sony Vaio VPCW21FX Keyboard Replacement: passo 4, immagine 3 di 3
    • Close the lid and flip the laptop over
    • Loosen but do not remove the screw on center panel and remove Panel.
  5. Sony Vaio VPCW21FX Keyboard Replacement: passo 5, immagine 1 di 2 Sony Vaio VPCW21FX Keyboard Replacement: passo 5, immagine 2 di 2
    • Remove the three 5mm screws that are holding in the keyboard.
  6. Sony Vaio VPCW21FX Keyboard Replacement: passo 6, immagine 1 di 3 Sony Vaio VPCW21FX Keyboard Replacement: passo 6, immagine 2 di 3 Sony Vaio VPCW21FX Keyboard Replacement: passo 6, immagine 3 di 3
    • Flip laptop over again and open the lid
    • Lift up the keyboard from the top and lean it toward you to expose the connector on the back
    • Grab the wire from the keyboard close to the connector and pull carefully to the left to disconnect it from the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 26
Tutti i Tempi: 2,221
