Salta al contenuto principale
Sony Vaio VPCW21FX Hard Drive Replacement
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. Sony Vaio VPCW21FX Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure your device is powered off and unplugged to avoid electric shock.
    • Place your device upside down with the bottom panel facing upwards.
    • Orient the device so the battery is away from you as shown
  2. Sony Vaio VPCW21FX Hard Drive Replacement: passo 2, immagine 1 di 2 Sony Vaio VPCW21FX Hard Drive Replacement: passo 2, immagine 2 di 2
    • Unlock the battery by sliding the lock switch to the right.
    • Locate the release latch. Slide the latch to the left to remove the battery from your laptop.
    • Be sure to lift up on the battery while you slide the latch to the left.
  3. Sony Vaio VPCW21FX Hard Drive Replacement: passo 3, immagine 1 di 2 Sony Vaio VPCW21FX Hard Drive Replacement: passo 3, immagine 2 di 2
    • Remove the battery from your laptop.
  4. Sony Vaio VPCW21FX Hard Drive Replacement, Hard Drive: passo 4, immagine 1 di 3 Sony Vaio VPCW21FX Hard Drive Replacement, Hard Drive: passo 4, immagine 2 di 3 Sony Vaio VPCW21FX Hard Drive Replacement, Hard Drive: passo 4, immagine 3 di 3
    • Remove the two 4.8mm screws that are holding the bottom right panel cover.
    • Remove the Panel cover by lifting it up.
  5. Sony Vaio VPCW21FX Hard Drive Replacement: passo 5, immagine 1 di 2 Sony Vaio VPCW21FX Hard Drive Replacement: passo 5, immagine 2 di 2
    • Remove the two 4.8mm screws that are holding the hard drive down.
  6. Sony Vaio VPCW21FX Hard Drive Replacement: passo 6, immagine 1 di 3 Sony Vaio VPCW21FX Hard Drive Replacement: passo 6, immagine 2 di 3 Sony Vaio VPCW21FX Hard Drive Replacement: passo 6, immagine 3 di 3
    • Grab the black tab that is attached to the hard drive.
    • Slide hard drive to the left to release it from the computer
    • Pull drive up from there and it will come out.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 530
