Salta al contenuto principale
Introduzione
This guide will show you how to replace the RAM in your Sony Vaio laptop.
  1. Start with the laptop face up on a flat surface.
    • Start with the laptop face up on a flat surface.
  2. Open the laptop with the keyboard facing you.
    • Open the laptop with the keyboard facing you.
  3. Use a plastic opening tool to pry up the keyboard. Start at the end closest to the screen. Be careful around the edges; work your way around the keyboard until all of it is detached.
    • Use a plastic opening tool to pry up the keyboard. Start at the end closest to the screen.
    • Be careful around the edges; work your way around the keyboard until all of it is detached.
    • There will be a ribbon cable attached to the bottom of the keyboard. Be sure not to rip the cable when lifting the keyboard from the laptop frame.
  4. Carefully detach the ribbon from the  base of the computer with your hands. Remove the keyboard.
    • Carefully detach the ribbon from the base of the computer with your hands.
    • Remove the keyboard.
  5. Kit di riparazione per Android
    A new screen or battery is one kit away.
    Acquista ora
    Acquista ora
  6. Use a Philips #0 screwdriver to remove the 7 top case screws.
    • Use a Philips #0 screwdriver to remove the 7 top case screws.
  7. Using a metal spudger, pry open at the seams.
    • Using a metal spudger, pry open at the seams.
    • Open the gray top of the laptop from the base black portion.
    • Slide the spudger along the seam, and then carefully open the top.
  8. Open the top carefully without disconnecting the two parts. Be mindful and careful of the ribbon cable attaching the two parts together.
    • Open the top carefully without disconnecting the two parts.
    • Be mindful and careful of the ribbon cable attaching the two parts together.
  9. Using your fingers, pry apart the two side metal pieces that hold the part in place as shown on the picture. Using your fingers, pry apart the two side metal pieces that hold the part in place as shown on the picture.
    • Using your fingers, pry apart the two side metal pieces that hold the part in place as shown on the picture.
  10. After that step, the RAM should pop up on its own as shown in the picture.
    • After that step, the RAM should pop up on its own as shown in the picture.
  11. Carefully press the sides near the right edge of the part and remove it from it's base. Carefully press the sides near the right edge of the part and remove it from it's base.
    • Carefully press the sides near the right edge of the part and remove it from it's base.
Conclusione
Giselle Dougan
Membro da: 31/01/2018
742 Reputazione
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 180
