Salta al contenuto principale
Sony Vaio VPCW211AX Fan Replacement
Cosa ti serve
  1. Sony Vaio VPCW211AX Fan Replacement, Keyboard: passo 1, immagine 1 di 1
    • Start with the laptop face up on a flat surface.
  2. Sony Vaio VPCW211AX Fan Replacement: passo 2, immagine 1 di 1
    • Open the laptop with the keyboard facing you.
  3. Sony Vaio VPCW211AX Fan Replacement: passo 3, immagine 1 di 2 Sony Vaio VPCW211AX Fan Replacement: passo 3, immagine 2 di 2
    • Use a plastic opening tool to pry up the keyboard. Start at the end closest to the screen.
    • Be careful around the edges; work your way around the keyboard until all of it is detached.
    • There will be a ribbon cable attached to the bottom of the keyboard. Be sure not to rip the cable when lifting the keyboard from the laptop frame.
  4. Sony Vaio VPCW211AX Fan Replacement: passo 4, immagine 1 di 2 Sony Vaio VPCW211AX Fan Replacement: passo 4, immagine 2 di 2
    • Carefully detach the ribbon from the base of the computer with your hands.
    • Remove the keyboard.
  5. Sony Vaio VPCW211AX Fan Replacement, Fan: passo 5, immagine 1 di 1
    • Use a Philips #0 screwdriver to remove the 7 top case screws.
  6. Sony Vaio VPCW211AX Fan Replacement: passo 6, immagine 1 di 1
    • Using a metal spudger, pry open at the seams.
    • Open the gray top of the laptop from the base black portion.
    • Slide the spudger along the seam, and then carefully open the top.
  7. Sony Vaio VPCW211AX Fan Replacement: passo 7, immagine 1 di 2 Sony Vaio VPCW211AX Fan Replacement: passo 7, immagine 2 di 2
    • Open the top carefully without disconnecting the two parts.
    • Be mindful and careful of the ribbon cable attaching the two parts together.
  8. Sony Vaio VPCW211AX Fan Replacement: passo 8, immagine 1 di 1
    • Use a Philips #0 screwdriver to unscrew the 4 heatsink screws.
  9. Sony Vaio VPCW211AX Fan Replacement: passo 9, immagine 1 di 1
    • If there is electrical tape, remove it with your finger.
  10. Sony Vaio VPCW211AX Fan Replacement: passo 10, immagine 1 di 1
    • Using the plastic opening tool, pry up the unscrewed fan.
  11. Sony Vaio VPCW211AX Fan Replacement: passo 11, immagine 1 di 2 Sony Vaio VPCW211AX Fan Replacement: passo 11, immagine 2 di 2
    • The fan will still be attached by a small red and yellow wire, with your fingers detach this carefully.
    • Remove the fan.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 689
