Salta al contenuto principale
Sony Vaio VPCEL17FX Hard Drive Replacement
Cosa ti serve
  1. Sony Vaio VPCEL17FX Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 3 Sony Vaio VPCEL17FX Hard Drive Replacement, Hard Drive: passo 1, immagine 2 di 3 Sony Vaio VPCEL17FX Hard Drive Replacement, Hard Drive: passo 1, immagine 3 di 3
    • First, locate the hard drive slot on the under side of the laptop.
    • Unscrew the screws using your Phillips #00 screwdriver.
    • Set the two screws aside so you can screw them in later on when you're finished.
    • This should reveal a small metallic place holder that your hard drive belongs.
  2. Sony Vaio VPCEL17FX Hard Drive Replacement: passo 2, immagine 1 di 2 Sony Vaio VPCEL17FX Hard Drive Replacement: passo 2, immagine 2 di 2
    • Unscrew the 4 hard drive bracket screws.
    • Once the screw is undone you can pull the place holder back to find the slot where the actual hard drive belongs.
    • Remember to set aside the screw so you can correctly install the hard drive.
Conclusione
The installation/replacement is a very easy task that can be done by anyone.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 621
