Salta al contenuto principale
Sony Vaio VPCEB11FM Cooling Fan Replacement
Cosa ti serve
  1. Sony Vaio VPCEB11FM Cooling Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Power down and disconnect the laptop from power supply.
    • Using your fingers, unlock the tab by pushing on the slide.
  2. Sony Vaio VPCEB11FM Cooling Fan Replacement: passo 2, immagine 1 di 1
    • While holding the release slide, use your thumb to lift the lip of the battery to pull it out.
  3. Sony Vaio VPCEB11FM Cooling Fan Replacement: passo 3, immagine 1 di 1
    • Pull the battery out.
  4. Sony Vaio VPCEB11FM Cooling Fan Replacement, RAM: passo 4, immagine 1 di 2 Sony Vaio VPCEB11FM Cooling Fan Replacement, RAM: passo 4, immagine 2 di 2
    • Unscrew the RAM cover plate using the Phillips #1 Screwdriver.
    • Once the cover has been loosened, pry the cover with your finger for it to come off.
  5. Sony Vaio VPCEB11FM Cooling Fan Replacement: passo 5, immagine 1 di 3 Sony Vaio VPCEB11FM Cooling Fan Replacement: passo 5, immagine 2 di 3 Sony Vaio VPCEB11FM Cooling Fan Replacement: passo 5, immagine 3 di 3
    • Use your fingers to gently pull the white plastic strip outward on both sides.
    • Once you pull the strip, the strip of RAM will loosen up. Once loose the strip of RAM should lift out.
    • Once done with the top strip of RAM continue for all continuous strips.
  6. Sony Vaio VPCEB11FM Cooling Fan Replacement, Hard Drive: passo 6, immagine 1 di 2 Sony Vaio VPCEB11FM Cooling Fan Replacement, Hard Drive: passo 6, immagine 2 di 2
    • Using the Phillips #01 Screwdriver, remove the two 7mm screws.
  7. Sony Vaio VPCEB11FM Cooling Fan Replacement: passo 7, immagine 1 di 3 Sony Vaio VPCEB11FM Cooling Fan Replacement: passo 7, immagine 2 di 3 Sony Vaio VPCEB11FM Cooling Fan Replacement: passo 7, immagine 3 di 3
    • Use your fingers to pry the cover upward.
    • Unscrew the two 7mm screws.
    • Pull the plastic tab in the direction of the arrow to take out.
  8. Sony Vaio VPCEB11FM Cooling Fan Replacement: passo 8, immagine 1 di 2 Sony Vaio VPCEB11FM Cooling Fan Replacement: passo 8, immagine 2 di 2
    • Lift plug side first.
    • Remove all the way.
  9. Sony Vaio VPCEB11FM Cooling Fan Replacement: passo 9, immagine 1 di 3 Sony Vaio VPCEB11FM Cooling Fan Replacement: passo 9, immagine 2 di 3 Sony Vaio VPCEB11FM Cooling Fan Replacement: passo 9, immagine 3 di 3
    • Skip to next step if accessing other components.
    • Remove the 3mm screws with the Phillips #1 Screwdriver from hard drive bracket.
  10. Sony Vaio VPCEB11FM Cooling Fan Replacement, DVD Drive: passo 10, immagine 1 di 2 Sony Vaio VPCEB11FM Cooling Fan Replacement, DVD Drive: passo 10, immagine 2 di 2
    • Remove the 7mm screws with the Phillips #1 Screwdriver.
  11. Sony Vaio VPCEB11FM Cooling Fan Replacement: passo 11, immagine 1 di 1
    • Grasp the DVD drive's face plate with your fingers and pull out.
  12. Sony Vaio VPCEB11FM Cooling Fan Replacement, Cooling Fan: passo 12, immagine 1 di 3 Sony Vaio VPCEB11FM Cooling Fan Replacement, Cooling Fan: passo 12, immagine 2 di 3 Sony Vaio VPCEB11FM Cooling Fan Replacement, Cooling Fan: passo 12, immagine 3 di 3
    • Remove ten 7mm screws with the Phillips #1 Screwdriver.
    • Remove two 8mm screws with the Phillips #1 Screwdriver.
    • Remove two 3mm screws with the Phillips #1 Screwdriver.
  13. Sony Vaio VPCEB11FM Cooling Fan Replacement: passo 13, immagine 1 di 2 Sony Vaio VPCEB11FM Cooling Fan Replacement: passo 13, immagine 2 di 2
    • Remove SD card slot block by pushing it in until it releases.
    • Once released pull out to remove.
  14. Sony Vaio VPCEB11FM Cooling Fan Replacement: passo 14, immagine 1 di 3 Sony Vaio VPCEB11FM Cooling Fan Replacement: passo 14, immagine 2 di 3 Sony Vaio VPCEB11FM Cooling Fan Replacement: passo 14, immagine 3 di 3
    • To take off the cover plate, start by finding a loose corner to begin prying it open.
    • Work the tool around the sides to release the cover. You may need a second tool to help keep your loose corner open.
    • Lift cover away.
    • NOTE: If you are attempting to access other components, skip 2 steps.
  15. Sony Vaio VPCEB11FM Cooling Fan Replacement: passo 15, immagine 1 di 3 Sony Vaio VPCEB11FM Cooling Fan Replacement: passo 15, immagine 2 di 3 Sony Vaio VPCEB11FM Cooling Fan Replacement: passo 15, immagine 3 di 3
    • Remove the plug shown using a pry tool.
    • Remove seven 5mm screws with the Phillips #01 Screwdriver.
  16. Sony Vaio VPCEB11FM Cooling Fan Replacement: passo 16, immagine 1 di 3 Sony Vaio VPCEB11FM Cooling Fan Replacement: passo 16, immagine 2 di 3 Sony Vaio VPCEB11FM Cooling Fan Replacement: passo 16, immagine 3 di 3
    • To break the thermal paste, apply gentle constant upward force until it comes free.
    • Remove four 3.5mm screws with the Phillips #000 Screwdriver to access cooling fan.
Conclusione
Altre 5 persone hanno completato questa guida.
Maxine Filcher
Membro da: 01/30/17
1.153 Reputazione
8 Guide realizzate
UW Tacoma, Team 1-5, Rose Winter 2017 Membro di UW Tacoma, Team 1-5, Rose Winter 2017
UWT-ROSE-W17S1G5
4 Membri
16 Guide realizzate
Un commento
Wonderful guide, helped me upgrade the CPU on my laptop and clean the insides out while I was at it.
William - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,967
