Salta al contenuto principale
Sony Vaio VPCEB11FM Audio Card Replacement
Cosa ti serve
  1. Sony Vaio VPCEB11FM Audio Card Replacement, Battery: passo 1, immagine 1 di 1
    • Power down and disconnect the laptop from power supply.
    • Using your fingers, unlock the tab by pushing on the slide.
  2. Sony Vaio VPCEB11FM Audio Card Replacement: passo 2, immagine 1 di 1
    • While holding the release slide, use your thumb to lift the lip of the battery to pull it out.
  3. Sony Vaio VPCEB11FM Audio Card Replacement: passo 3, immagine 1 di 1
    • Pull the battery out.
  4. Sony Vaio VPCEB11FM Audio Card Replacement, RAM: passo 4, immagine 1 di 2 Sony Vaio VPCEB11FM Audio Card Replacement, RAM: passo 4, immagine 2 di 2
    • Unscrew the RAM cover plate using the Phillips #1 Screwdriver.
    • Once the cover has been loosened, pry the cover with your finger for it to come off.
  5. Sony Vaio VPCEB11FM Audio Card Replacement: passo 5, immagine 1 di 3 Sony Vaio VPCEB11FM Audio Card Replacement: passo 5, immagine 2 di 3 Sony Vaio VPCEB11FM Audio Card Replacement: passo 5, immagine 3 di 3
    • Use your fingers to gently pull the white plastic strip outward on both sides.
    • Once you pull the strip, the strip of RAM will loosen up. Once loose the strip of RAM should lift out.
    • Once done with the top strip of RAM continue for all continuous strips.
  6. Sony Vaio VPCEB11FM Audio Card Replacement, Hard Drive: passo 6, immagine 1 di 2 Sony Vaio VPCEB11FM Audio Card Replacement, Hard Drive: passo 6, immagine 2 di 2
    • Using the Phillips #01 Screwdriver, remove the two 7mm screws.
  7. Sony Vaio VPCEB11FM Audio Card Replacement: passo 7, immagine 1 di 3 Sony Vaio VPCEB11FM Audio Card Replacement: passo 7, immagine 2 di 3 Sony Vaio VPCEB11FM Audio Card Replacement: passo 7, immagine 3 di 3
    • Use your fingers to pry the cover upward.
    • Unscrew the two 7mm screws.
    • Pull the plastic tab in the direction of the arrow to take out.
  8. Sony Vaio VPCEB11FM Audio Card Replacement: passo 8, immagine 1 di 2 Sony Vaio VPCEB11FM Audio Card Replacement: passo 8, immagine 2 di 2
    • Lift plug side first.
    • Remove all the way.
  9. Sony Vaio VPCEB11FM Audio Card Replacement: passo 9, immagine 1 di 3 Sony Vaio VPCEB11FM Audio Card Replacement: passo 9, immagine 2 di 3 Sony Vaio VPCEB11FM Audio Card Replacement: passo 9, immagine 3 di 3
    • Skip to next step if accessing other components.
    • Remove the 3mm screws with the Phillips #1 Screwdriver from hard drive bracket.
  10. Sony Vaio VPCEB11FM Audio Card Replacement, Audio Card: passo 10, immagine 1 di 3 Sony Vaio VPCEB11FM Audio Card Replacement, Audio Card: passo 10, immagine 2 di 3 Sony Vaio VPCEB11FM Audio Card Replacement, Audio Card: passo 10, immagine 3 di 3
    • #1 Unscrew the back panel
    • #2 Then work the tool around the sides to release cover. You may need a second tool to help keep your loose corner open.
  11. Sony Vaio VPCEB11FM Audio Card Replacement: passo 11, immagine 1 di 3 Sony Vaio VPCEB11FM Audio Card Replacement: passo 11, immagine 2 di 3 Sony Vaio VPCEB11FM Audio Card Replacement: passo 11, immagine 3 di 3
    • Unscrew the screw with the size of * screw driver
    • Left up the case holder
    • Gently pull the connective cable
Conclusione
Altre 3 persone hanno completato questa guida.
Maxine Filcher
Membro da: 01/30/17
1.153 Reputazione
8 Guide realizzate
UW Tacoma, Team 1-5, Rose Winter 2017 Membro di UW Tacoma, Team 1-5, Rose Winter 2017
UWT-ROSE-W17S1G5
4 Membri
16 Guide realizzate
Un commento
I appreciate it
Thedeen - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,110
