Salta al contenuto principale
Sony Vaio VPCCW17FX Speakers Replacement
Cosa ti serve
  1. Sony Vaio VPCCW17FX Speakers Replacement, Speakers: passo 1, immagine 1 di 1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Speakers Replacement: passo 2, immagine 1 di 1
    • Slide the two latches towards the center of the laptop in order to release the battery.
  3. Sony Vaio VPCCW17FX Speakers Replacement: passo 3, immagine 1 di 2 Sony Vaio VPCCW17FX Speakers Replacement: passo 3, immagine 2 di 2
    • Use fingernail or plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX Speakers Replacement: passo 4, immagine 1 di 2 Sony Vaio VPCCW17FX Speakers Replacement: passo 4, immagine 2 di 2
    • Using a Phillips #0 screwdriver to remove the two screws (Length: 7.7 mm) of the Hard Drive cover and place the cover to the side.
    • Using a Phillips #0 screwdriver, remove the one screw (Length: 7.7 mm) from the RAM cover and place it to the side.
  5. Sony Vaio VPCCW17FX Speakers Replacement: passo 5, immagine 1 di 1
    • Using a Phillips #0 screwdriver, remove all twelve screws (Length: 7.7 mm) that hold the bottom cover.
  6. Sony Vaio VPCCW17FX Speakers Replacement: passo 6, immagine 1 di 1
    • Lift and remove the back cover.
  7. Sony Vaio VPCCW17FX Speakers Replacement: passo 7, immagine 1 di 2 Sony Vaio VPCCW17FX Speakers Replacement: passo 7, immagine 2 di 2
    • Locate the fan and use a Phillips #0 screwdriver, remove the two screws (Length: 7.7 mm) that hold it in place.
    • Lift the fan and move it out of the way.
  8. Sony Vaio VPCCW17FX Speakers Replacement: passo 8, immagine 1 di 2 Sony Vaio VPCCW17FX Speakers Replacement: passo 8, immagine 2 di 2
    • Begin removing the four screws with a Phillips #0 screwdriver (Length: 7.7 mm) from the back cover.
    • Place the cover out of the way.
    • Be careful to not pull any wires out while moving the cover.
  9. Sony Vaio VPCCW17FX Speakers Replacement: passo 9, immagine 1 di 3 Sony Vaio VPCCW17FX Speakers Replacement: passo 9, immagine 2 di 3 Sony Vaio VPCCW17FX Speakers Replacement: passo 9, immagine 3 di 3
    • Using a Phillips #0 screwdriver, remove the two screws (Length: 7.7 mm) that hold the speaker in place.
    • Follow the wire until you find the ribbon cable that holds the wires and pull straight out of the connect to remove it.
    • You are now free to replace the speakers.
    • There are two speakers so be sure to repeat the same steps for the second speaker.
Conclusione
Brianna Rukes
Membro da: 03/21/17
101 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 14
Tutti i Tempi: 486
