Salta al contenuto principale
Sony Vaio VPCCW17FX LCD Screen Replacement
Cosa ti serve
  1. Sony Vaio VPCCW17FX LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX LCD Screen Replacement: passo 2, immagine 1 di 1
    • Slide both latches towards the center of the battery to release.
  3. Sony Vaio VPCCW17FX LCD Screen Replacement: passo 3, immagine 1 di 2 Sony Vaio VPCCW17FX LCD Screen Replacement: passo 3, immagine 2 di 2
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX LCD Screen Replacement: passo 4, immagine 1 di 2 Sony Vaio VPCCW17FX LCD Screen Replacement: passo 4, immagine 2 di 2
    • Remove the rubber pads on all four corners of the screen bezel using the spudger.
    • Remove the four screws (Length: 7.7 mm) using the Phillips #0 screwdriver.
  5. Sony Vaio VPCCW17FX LCD Screen Replacement: passo 5, immagine 1 di 1
    • Remove the screen's plastic bezel.
    • You need to use slight pressure to release the clips.
  6. Sony Vaio VPCCW17FX LCD Screen Replacement: passo 6, immagine 1 di 2 Sony Vaio VPCCW17FX LCD Screen Replacement: passo 6, immagine 2 di 2
    • Remove all four screws (Length: 7.7 mm) using a Phillips #0 screwdriver. Make sure to hold the screen while removing the screws so it doesn't fall.
    • Using your thumb, carefully lower the glass and place it on the keyboard.
    • Do this slowly to avoid damaging the screen.
  7. Sony Vaio VPCCW17FX LCD Screen Replacement: passo 7, immagine 1 di 2 Sony Vaio VPCCW17FX LCD Screen Replacement: passo 7, immagine 2 di 2
    • Pull off the tape and disconnect the display cable connector by gently sliding up to remove it from its socket.
  8. Sony Vaio VPCCW17FX LCD Screen Replacement: passo 8, immagine 1 di 1
    • The screen can now be removed.
Conclusione
Seowon Song
Membro da: 03/20/17
113 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,294
