Salta al contenuto principale
Sony Vaio VGN-SR140E Hard Drive Replacement
Cosa ti serve
  1. Sony Vaio VGN-SR140E Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E Hard Drive Replacement: passo 2, immagine 1 di 1
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E Hard Drive Replacement: passo 3, immagine 1 di 2 Sony Vaio VGN-SR140E Hard Drive Replacement: passo 3, immagine 2 di 2
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E Hard Drive Replacement, Hard Drive: passo 4, immagine 1 di 1
    • Using a Phillips #1 screw driver, loosen both screws holding the cover in place. These screws are secured to the cover with retaining clips.
  5. Sony Vaio VGN-SR140E Hard Drive Replacement: passo 5, immagine 1 di 1
    • Lift the cover with a fingernail or plastic opening tool from the side where the screws are present and lift it off to the left.
  6. Sony Vaio VGN-SR140E Hard Drive Replacement: passo 6, immagine 1 di 1
    • The hard drive is covered by a thin, black, plastic flap. Gently lift the hard drive up and to the right.
    • Be careful not to damage the ribbon cable during this step.
  7. Sony Vaio VGN-SR140E Hard Drive Replacement: passo 7, immagine 1 di 2 Sony Vaio VGN-SR140E Hard Drive Replacement: passo 7, immagine 2 di 2
    • Use the spudger or a fingernail to carefully release the lock securing the ribbon cable to the motherboard.
  8. Sony Vaio VGN-SR140E Hard Drive Replacement: passo 8, immagine 1 di 2 Sony Vaio VGN-SR140E Hard Drive Replacement: passo 8, immagine 2 di 2
    • Grasp the ribbon cable carefully near the connector end. Remove it by pulling the cable away from the connector on the motherboard at a slightly upward angle.
Conclusione
Jeremy
Membro da: 03/18/15
722 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 930
