Salta al contenuto principale
Sony Vaio VGN-SR140E CD/DVD Drive Replacement
Cosa ti serve
  1. Sony Vaio VGN-SR140E CD/DVD Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: passo 2, immagine 1 di 1
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: passo 3, immagine 1 di 2 Sony Vaio VGN-SR140E CD/DVD Drive Replacement: passo 3, immagine 2 di 2
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E CD/DVD Drive Replacement, CD/DVD Drive: passo 4, immagine 1 di 1
    • Use a Phillips #1 screwdriver to loosen all four screws. These screws are secured to their covers with retaining clips.
  5. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: passo 5, immagine 1 di 1
    • Lift the two covers with a fingernail or plastic opening tool from the sides the screws were present. Two tabs are securing the covers on the side opposite the screws.
  6. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: passo 6, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove both 6.5mm screws and set them aside.
  7. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: passo 7, immagine 1 di 1
    • Gently slide the CD/DVD drive out of the laptop.
Conclusione
Jeremy
Membro da: 03/18/15
722 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 965
