Salta al contenuto principale
Sony Vaio VGN-FS640 RAM Cover Replacement
Cosa ti serve
  1. Sony Vaio VGN-FS640 RAM Cover Replacement, Battery: passo 1, immagine 1 di 1
    • Lay the closed laptop on its screen so the bottom is facing towards you.
  2. Sony Vaio VGN-FS640 RAM Cover Replacement: passo 2, immagine 1 di 1
    • Push both latches towards the center of the battery.
  3. Sony Vaio VGN-FS640 RAM Cover Replacement: passo 3, immagine 1 di 2 Sony Vaio VGN-FS640 RAM Cover Replacement: passo 3, immagine 2 di 2
    • Revome the battery by pushing it away from the laptop.
    • Set the battery away from the laptop.
  4. Sony Vaio VGN-FS640 RAM Cover Replacement, RAM Cover: passo 4, immagine 1 di 2 Sony Vaio VGN-FS640 RAM Cover Replacement, RAM Cover: passo 4, immagine 2 di 2
    • With the bottom of the laptop facing up, locate the RAM cover.
    • The RAM is covered by the panel with four columns of vents.
    • Locate the screw (Length: 4.8 mm) holding down the panel, which is near the edge of the laptop. Unscrew it with your phillips #0 screwdriver.
  5. Sony Vaio VGN-FS640 RAM Cover Replacement: passo 5, immagine 1 di 3 Sony Vaio VGN-FS640 RAM Cover Replacement: passo 5, immagine 2 di 3 Sony Vaio VGN-FS640 RAM Cover Replacement: passo 5, immagine 3 di 3
    • Use your fingers to slide the cover away from the laptop. (It will only slide a few millimeters)
    • Once the panel is out of its locked position, it can be lifted out without any resistance.
Conclusione
Cal Poly, Team 24-32, Regan Spring 2010 Membro di Cal Poly, Team 24-32, Regan Spring 2010
CPSU-REGAN-S10S24G32
4 Membri
16 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 76
Tutti i Tempi: 5,206
