Salta al contenuto principale
Sony Vaio Tap 21 SVT212A11L Hard Drive Replacement
Cosa ti serve
  1. Sony Vaio Tap 21 SVT212A11L Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Locate the hard drive.
  2. Sony Vaio Tap 21 SVT212A11L Hard Drive Replacement: passo 2, immagine 1 di 2 Sony Vaio Tap 21 SVT212A11L Hard Drive Replacement: passo 2, immagine 2 di 2
    • Locate the 13mm screws for the hard drive and use the JIS 0 screwdriver to unscrew.
  3. Sony Vaio Tap 21 SVT212A11L Hard Drive Replacement: passo 3, immagine 1 di 3 Sony Vaio Tap 21 SVT212A11L Hard Drive Replacement: passo 3, immagine 2 di 3 Sony Vaio Tap 21 SVT212A11L Hard Drive Replacement: passo 3, immagine 3 di 3
    • Gently lift the hard drive upwards.
    • Ensure you have a gentle hold on the hard drive cable.
    • Gently pull the cable from the base where the cable header meets the hard drive.
    • To ensure no damage is done on the cable header, pull the header gently from both sides at the same time or gently from the center.
  4. Sony Vaio Tap 21 SVT212A11L Hard Drive Replacement: passo 4, immagine 1 di 2 Sony Vaio Tap 21 SVT212A11L Hard Drive Replacement: passo 4, immagine 2 di 2
    • Locate the screws.
    • Using the JIS 0 screwdriver, unscrew the 4mm screws.
    • Gently lift the frame after screws have been taken out.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team S4-G4, Livingston Fall 2017 Membro di Cal Poly, Team S4-G4, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G4
4 Membri
12 Guide realizzate
12 Commenti
Is that a M.2 SSD Slot on the motherboard?
tedsoldier - Replica
Nope, that’s an mPCIE/mSATA slot, not an m.2 slot. Look at the retention screw position: m.2 uses a centre screw, mPCIE/mSATA uses a corner screw.
Spencer Martin Navarra Chew -
Yes, there is an M.2 SSD slot on the left side of the motherboard. I’ve installed a 256GB SSD in the slot on my VT21
Bill Scharf - Replica
No, it’s clearly an mPCIE/mSATA slot, not m.2. The pin/notch configuration and retention screw position make it easy to identify.
You must be using a mPCIE or mSATA SSD.
Spencer Martin Navarra Chew is correct about this slot. My mistake.
Bill Scharf -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 46
Tutti i Tempi: 5,377
