Salta al contenuto principale
Sony Vaio Tap 11 Wifi Module Replacement
Cosa ti serve
  1. Sony Vaio Tap 11 Wifi Module Replacement, Screen Assembly: passo 1, immagine 1 di 1
    • Begin by opening the HDMI/USB port cover on the left edge.
    • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
  2. Sony Vaio Tap 11 Wifi Module Replacement: passo 2, immagine 1 di 1
    • Locate and open the Micro SD slot on the top side of the device.
    • Remove the two screws located beneath the cover.
  3. Sony Vaio Tap 11 Wifi Module Replacement: passo 3, immagine 1 di 2 Sony Vaio Tap 11 Wifi Module Replacement: passo 3, immagine 2 di 2
    • Attach the suction cup to the top right area of the screen.
    • Pull to separate the screen from the rest of the device.
    • Be aware of the front camera cable that is still connected to the rest of the device.
    • Detach the display ribbon cable.
  4. Sony Vaio Tap 11 Wifi Module Replacement, Solid State Disk: passo 4, immagine 1 di 1
    • Unplug the battery connector located beside the fan.
    • Locate the SSD on the right side of the device, above the battery and beneath the WiFi chip.
  5. Sony Vaio Tap 11 Wifi Module Replacement: passo 5, immagine 1 di 1
    • Remove the two 3 mm Phillips #000 screws from the right edge of the SSD.
  6. Sony Vaio Tap 11 Wifi Module Replacement: passo 6, immagine 1 di 2 Sony Vaio Tap 11 Wifi Module Replacement: passo 6, immagine 2 di 2
    • Pull the SSD towards the right and slightly up, removing it from the back assembly.
  7. Sony Vaio Tap 11 Wifi Module Replacement, Wifi Module: passo 7, immagine 1 di 3 Sony Vaio Tap 11 Wifi Module Replacement, Wifi Module: passo 7, immagine 2 di 3 Sony Vaio Tap 11 Wifi Module Replacement, Wifi Module: passo 7, immagine 3 di 3
    • Begin by removing the orange ribbon cable connecting the motherboard to the daughterboard, located above the SSD.
    • Gently tug either side until it releases, then pull out the other end.
  8. Sony Vaio Tap 11 Wifi Module Replacement: passo 8, immagine 1 di 1
    • Remove the grey foam separator that was underneath the orange ribbon cable.
  9. Sony Vaio Tap 11 Wifi Module Replacement: passo 9, immagine 1 di 1
    • Remove the silver 3 mm Phillips screw that holds the WiFi module in place.
  10. Sony Vaio Tap 11 Wifi Module Replacement: passo 10, immagine 1 di 1
    • Remove the black and grey antenna cables from the right side of the device.
  11. Sony Vaio Tap 11 Wifi Module Replacement: passo 11, immagine 1 di 1
    • Remove module by gently pulling towards the right.
Conclusione
Altre 2 persone hanno completato questa guida.
IUPUI, Team 1-2, Harley Fall 2015 Membro di IUPUI, Team 1-2, Harley Fall 2015
IUPUI-HARLEY-F15S1G2
4 Membri
20 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,935
