Salta al contenuto principale
Sony Vaio SVT151A11L USB Port Board Replacement
Cosa ti serve
  1. Sony Vaio SVT151A11L USB Port Board Replacement, Battery: passo 1, immagine 1 di 2 Sony Vaio SVT151A11L USB Port Board Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the laptop over so that the battery on the underside of the device is revealed.
    • Unscrew the two 11mm slotted silver screws that can be found at the top of the battery.
  2. Sony Vaio SVT151A11L USB Port Board Replacement: passo 2, immagine 1 di 3 Sony Vaio SVT151A11L USB Port Board Replacement: passo 2, immagine 2 di 3 Sony Vaio SVT151A11L USB Port Board Replacement: passo 2, immagine 3 di 3
    • Wedge the plastic opening tool between the back panel and the battery on the top left side of the device.
    • Push down on the plastic opening tool until the battery lifts from the back of the laptop.
    • Grab the battery and remove it from the device.
  3. Sony Vaio SVT151A11L USB Port Board Replacement, Back Panel: passo 3, immagine 1 di 3 Sony Vaio SVT151A11L USB Port Board Replacement, Back Panel: passo 3, immagine 2 di 3 Sony Vaio SVT151A11L USB Port Board Replacement, Back Panel: passo 3, immagine 3 di 3
    • Unscrew the three 4mm screws using a JIS #0 screwdriver.
    • Unscrew the eight 7 mm screws using a JIS #0 screwdriver.
    • Grab and lift the edge of the panel to pull it free from the rest of the computer.
  4. Sony Vaio SVT151A11L USB Port Board Replacement: passo 4, immagine 1 di 3 Sony Vaio SVT151A11L USB Port Board Replacement: passo 4, immagine 2 di 3 Sony Vaio SVT151A11L USB Port Board Replacement: passo 4, immagine 3 di 3
    • Grab the disk drive located at the edge of the computer and pull it it out.
    • Unscrew the three 7 mm screws with a JIS #0 screwdriver.
  5. Sony Vaio SVT151A11L USB Port Board Replacement, USB Port Board: passo 5, immagine 1 di 2 Sony Vaio SVT151A11L USB Port Board Replacement, USB Port Board: passo 5, immagine 2 di 2
    • Use a JIS #0 screwdriver to unscrew the two 4mm screws from the board.
  6. Sony Vaio SVT151A11L USB Port Board Replacement: passo 6, immagine 1 di 3 Sony Vaio SVT151A11L USB Port Board Replacement: passo 6, immagine 2 di 3 Sony Vaio SVT151A11L USB Port Board Replacement: passo 6, immagine 3 di 3
    • Lift board and peel the ribbon cable from the computer.
    • Lift and pull the end of the ribbon cable to remove it from the slot.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,052
