Salta al contenuto principale
Sony Vaio SVF15A16CXB Battery Replacement
Cosa ti serve
  1. Sony Vaio SVF15A16CXB Battery Replacement, Back Panel: passo 1, immagine 1 di 1
    • Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • Unscrew the one 4 mm screw from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • 6 mm screws marked in red, 4 mm marked in orange
  2. Sony Vaio SVF15A16CXB Battery Replacement: passo 2, immagine 1 di 2 Sony Vaio SVF15A16CXB Battery Replacement: passo 2, immagine 2 di 2
    • Using a plastic opening tool, pull the optical drive out of the computer by the seam.
    • In reassembly, slide the optical drive back in after reapplying cover.
  3. Sony Vaio SVF15A16CXB Battery Replacement: passo 3, immagine 1 di 1
    • Run the opening tool along the bottom cover seam.
  4. Sony Vaio SVF15A16CXB Battery Replacement: passo 4, immagine 1 di 1
    • Lift the clip marked in red in order to release the back cover.
    • Lift the back cover.
  5. Sony Vaio SVF15A16CXB Battery Replacement, Battery: passo 5, immagine 1 di 1
    • Unscrew the four 6mm screws with the Phillips #0 screwdriver.
  6. Sony Vaio SVF15A16CXB Battery Replacement: passo 6, immagine 1 di 1
    • Lift the battery and remove it from the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,714
