Salta al contenuto principale
Sony Vaio SVE171C11L RAM Replacement
Cosa ti serve
  1. Sony Vaio SVE171C11L RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop over so its underside is facing upwards and visible.
  2. Sony Vaio SVE171C11L RAM Replacement: passo 2, immagine 1 di 1
    • Once you flip the laptop over, make sure the right tab is pushed upwards to unlock it.
    • Use your left hand to push up the left tab to release the battery.
  3. Sony Vaio SVE171C11L RAM Replacement: passo 3, immagine 1 di 1
    • After the battery is released, locate the small gap where the battery and the shell meet. Then lift the gap up and rotate the battery up and away from yourself.
  4. Sony Vaio SVE171C11L RAM Replacement: passo 4, immagine 1 di 1
    • Pull the battery away.
  5. Sony Vaio SVE171C11L RAM Replacement, RAM: passo 5, immagine 1 di 1
    • Unscrew the single 3mm screw to remove the RAM panel.
  6. Sony Vaio SVE171C11L RAM Replacement: passo 6, immagine 1 di 1
    • Use both hands to unlock the clips that are securing the RAM.
    • The RAM will pop out from the slot when release the clip. After unlocking, slide out the RAM from their slots.
    • When inserting new RAM do not forget the put the clips back on.
Conclusione
CSU Los Angeles, Team 6-3, Adachi Fall 2022 Membro di CSU Los Angeles, Team 6-3, Adachi Fall 2022
CSULA-ADACHI-F22S6G3
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 7
Tutti i Tempi: 122
