Salta al contenuto principale
Sony Vaio SVE171C11L Motherboard Replacement
Cosa ti serve
  1. Sony Vaio SVE171C11L Motherboard Replacement, Motherboard: passo 1, immagine 1 di 2 Sony Vaio SVE171C11L Motherboard Replacement, Motherboard: passo 1, immagine 2 di 2
    • Turn the laptop facedown.
    • Locate the battery compartment at the top of the laptop base. You will see two tabs on it.
    • Push the two tabs up to release the battery. Set it aside.
  2. Sony Vaio SVE171C11L Motherboard Replacement: passo 2, immagine 1 di 2 Sony Vaio SVE171C11L Motherboard Replacement: passo 2, immagine 2 di 2
    • Rotate the laptop so the empty battery compartment is now at the bottom.
    • Remove the two screws that secure the hard drive cover using a T5 Torx screwdriver. Set it aside.
  3. Sony Vaio SVE171C11L Motherboard Replacement: passo 3, immagine 1 di 2 Sony Vaio SVE171C11L Motherboard Replacement: passo 3, immagine 2 di 2
    • Remove the three screws securing the hard drive disk in place.
    • Use the blue ribbon attached to the hard drive disk to carefully remove it from laptop. Set it aside.
  4. Sony Vaio SVE171C11L Motherboard Replacement: passo 4, immagine 1 di 1
    • Remove all screws holding the back panel from the laptop.
    • Carefully pull up the back panel to remove it.
  5. Sony Vaio SVE171C11L Motherboard Replacement: passo 5, immagine 1 di 3 Sony Vaio SVE171C11L Motherboard Replacement: passo 5, immagine 2 di 3 Sony Vaio SVE171C11L Motherboard Replacement: passo 5, immagine 3 di 3
    • Remove the cables from the fan and unscrew the heatsink.
    • The heatsink has many metal pieces jutting out from its base and is located under the fan.
    • Carefully disconnect the tabs on the edges of the motherboard.
    • Unscrew the screws holding the motherboard in place. Set them aside.
    • On the underside of the motherboard, disconnect the keyboard from the motherboard.
    • Once ALL cables are disconnected, carefully remove the motherboard.
Conclusione
CSU Los Angeles, Team 6-3, Adachi Fall 2022 Membro di CSU Los Angeles, Team 6-3, Adachi Fall 2022
CSULA-ADACHI-F22S6G3
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 327
