Salta al contenuto principale
Sony Vaio SVE15112FXS Hard Drive Replacement
Cosa ti serve
  1. Sony Vaio SVE15112FXS Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Power laptop off before beginning.
    • Turn the laptop over so that it is positioned top down with the model number facing you.
  2. Sony Vaio SVE15112FXS Hard Drive Replacement: passo 2, immagine 1 di 1
    • Use a #0 Phillips screwdriver to remove the two 4.0 mm screws securing the hard drive cover.
    • To avoid losing any parts, we recommend that you place the loose screws on a magnetic project mat.
  3. Sony Vaio SVE15112FXS Hard Drive Replacement: passo 3, immagine 1 di 2 Sony Vaio SVE15112FXS Hard Drive Replacement: passo 3, immagine 2 di 2
    • To expose the hard drive, remove the cover by sliding it toward you and pulling up on the panel.
  4. Sony Vaio SVE15112FXS Hard Drive Replacement: passo 4, immagine 1 di 1
    • Use a #0 Phillips screwdriver to remove the two 4.0 mm screws attaching the hard drive to the laptop.
  5. Sony Vaio SVE15112FXS Hard Drive Replacement: passo 5, immagine 1 di 2 Sony Vaio SVE15112FXS Hard Drive Replacement: passo 5, immagine 2 di 2
    • Pull the clear plastic ribbon to the left until the mount is detached from the laptop.
    • There will be some resistance as the hard drive is disconnected. If it does not move at all, check that all anchor screws are removed.
    • Lift the hard drive out of the well.
  6. Sony Vaio SVE15112FXS Hard Drive Replacement: passo 6, immagine 1 di 2 Sony Vaio SVE15112FXS Hard Drive Replacement: passo 6, immagine 2 di 2
    • Use a #0 Phillips screwdriver to remove the four 4.0 mm screws attaching the mount to the hard drive.
    • Slide the hard drive away from the mount until it is completely detached.
    • Take note of how the mount is positioned when attached to the hard drive.
Conclusione
Ashley Bierman
Membro da: 09/06/18
1.223 Reputazione
5 Guide realizzate
Ohio State, Team S1-G1, Whitney Fall 2018 Membro di Ohio State, Team S1-G1, Whitney Fall 2018
OSU-WHITNEY-F18S1G1
2 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 12
Tutti i Tempi: 700
