Salta al contenuto principale
Sony Vaio SVE111B11L Keyboard Assembly Replacement
Cosa ti serve
  1. Sony Vaio SVE111B11L Keyboard Assembly Replacement, Battery: passo 1, immagine 1 di 2 Sony Vaio SVE111B11L Keyboard Assembly Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the charging adaptor. Some charge may still be in the battery or computer. DO NOT touch connectors or copper yellow connector.
    • Locate the battery on the bottom of the computer.
    • Flip the computer so that the battery faces you.
  2. Sony Vaio SVE111B11L Keyboard Assembly Replacement: passo 2, immagine 1 di 1
    • Locate the two latches with the words “lock” and “release” on them.
  3. Sony Vaio SVE111B11L Keyboard Assembly Replacement: passo 3, immagine 1 di 1
    • Push the latches towards each other and lift the battery to remove it.
  4. Sony Vaio SVE111B11L Keyboard Assembly Replacement, Keyboard Assembly: passo 4, immagine 1 di 1
    • Remove the memory door on the bottom of the computer to access the screw for the keyboard.
    • The screws for the memory door do not come out.
  5. Sony Vaio SVE111B11L Keyboard Assembly Replacement: passo 5, immagine 1 di 1
    • Remove the 6.7 mm screw that holds the keyboard assembly in place.
  6. Sony Vaio SVE111B11L Keyboard Assembly Replacement: passo 6, immagine 1 di 1
    • Be careful not to break the keyboard wire connection.
    • Slide the wires out, away from the solder connections.
    • Flip the computer over and open it.
  7. Sony Vaio SVE111B11L Keyboard Assembly Replacement: passo 7, immagine 1 di 3 Sony Vaio SVE111B11L Keyboard Assembly Replacement: passo 7, immagine 2 di 3 Sony Vaio SVE111B11L Keyboard Assembly Replacement: passo 7, immagine 3 di 3
    • Gently pry the keyboard assembly from the screen side, using an opening tool. You will need to lift the keyboard about two inches.
    • Using an opening tool, gently pull out and slightly up on the connector clip.
    • Gently lift the keyboard assembly up and out.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,205
