Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
This guide shows how to remove the screen of a Sony Vaio SVE111B11L. This repair may be needed if the screen melts or cracks. To replace the screen follow the guide in reverse order.
Parti
Nessuna parte specificata.
  1. Remove charging adaptor. Some charge may still be in the battery or computer. DO NOT touch connectors or copper yellow connector. Locate the battery on the bottom of the computer.
    • Remove charging adaptor. Some charge may still be in the battery or computer. DO NOT touch connectors or copper yellow connector.
    • Locate the battery on the bottom of the computer.
    • Flip Computer Toward Yourself
  2. Locate two latches with the words “lock” and “release” on them. You will use these in the next step.
    • Locate two latches with the words “lock” and “release” on them. You will use these in the next step.
  3. Push the latches towards each other while simultaneously lifting up the battery.
    • Push the latches towards each other while simultaneously lifting up the battery.
  4. Remove charging adaptor. Some charge may still be in the battery or computer.
    • DO NOT touch connectors or copper yellow connector.
    • Remove the memory door on the bottom of the computer to access the screw for the keyboard.
    • The screws for the memory door do not come out. they are held from falling out.
  5. Locate the screw that holds the keyboard assembly in place.
    • Locate the screw that holds the keyboard assembly in place.
    • Remove this screw.
    • Size: L 6.7mm X D 1.9mm
  6. LCD iPhone Screen Fix Kits
    The budget option, covered by our Lifetime Warranty.
    Shop Kits
    Cut repair costs, not quality.
    Shop Kits
  7. Be careful of the keyboard wire connection.
    • Be careful of the keyboard wire connection.
    • Slide the wires out. Make sure to slide away from the solder connections.
    • Flip computer over and open.
  8. Gently pry the keyboard assembly from the front. (closest to the screen) With the blue spudger. Pry until the keyboard is about two inches up. Pull out and up slightly on the connector clip carefully. (Use the  blue spudger)
    • Gently pry the keyboard assembly from the front. (closest to the screen) With the blue spudger.
    • Pry until the keyboard is about two inches up.
    • Pull out and up slightly on the connector clip carefully. (Use the blue spudger)
    • Gently lift the key board assembly up and out.
  9. Remove charging adaptor. Some charge may still be in the battery or computer.
    • Take the covers over the motherboard off.
  10. Locate and remove the screws holding the motherboard down.
    • Locate and remove the screws holding the motherboard down.
    • Screws: L 4.6mm X D 1.85mm
  11. Locate the wires and connectors. Unplug any connectors that are interfering with the removal of the motherboard. Unplug any connectors that are interfering with the removal of the motherboard.
    • Locate the wires and connectors.
    • Unplug any connectors that are interfering with the removal of the motherboard.
  12. Gently lift the mother board out, being careful of the loose connectors and wires Gently lift the mother board out, being careful of the loose connectors and wires
    • Gently lift the mother board out, being careful of the loose connectors and wires
  13. Remove charging adaptor and battery. Some charge may still be in the battery or computer. DO NOT touch connectors or copper yellow connector.
    • Remove charging adaptor and battery. Some charge may still be in the battery or computer.
    • Locate screws. L 3.35mm X D 1.8mm
    • Remove Screws.
    • Lay the screen on a hard flat surface.
    • Remove hinges and wires for ease of removal.
  14. Gently remove the screen cover.
    • Gently remove the screen cover.
    • Be careful of the camera at the top of the screen.
    • Be careful of the seal tape between the cover and the screen.
  15. Locate the wires and connectors. Unplug the wires from the connectors. Be careful of the yellow tape around the connection.
    • Unplug the wires from the connectors.
    • Be careful of the yellow tape around the connection.
  16. Gently lift the screen assembly up and out. Gently lift the screen assembly up and out.
    • Gently lift the screen assembly up and out.
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 12
Tutti i Tempi: 822
