Introduzione
Replacement of SSD
Cosa ti serve
Remove cover for the extended battery connector. Use your finger nail or a plastic opening tool to remove it.
Remove the two rubber feet at the back of the computer, these can be removed in the same way.
Remove the 4mm #0 Philips screw holding down the SSD
Lift the SSD up and slide out of the slot
Altre 10 persone hanno completato questa guida.
4 Commenti
My internal hard drive does not get detected sometimes. I had this same problem a few months back. Upon getting it repaired by computer technician, I was told the issue was in the hard drive cover which connects the SSD to the PC. The issue got fixed at a cost of $100. I am not sure what that meant but the same issue has returned.
I don't believe I have to replace my solid state drive. Can anyone offer me any solutions?
Hello Sagar, I have the same issue, did you get it fixed eventually?
Thanks! Olivier
Yes, if this one slot stick on Sony 13Pro, it needs to be ahci-pcie, not nvme. NVME does not boot without editing bios code.
