Salta al contenuto principale
Sony Vaio PCG-F360 Optical Drive Replacement
Cosa ti serve
  1. Sony Vaio PCG-F360 Optical Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Position the laptop screen-side down as shown.
    • In this position the battery housing will be located on the right hand side.
  2. Sony Vaio PCG-F360 Optical Drive Replacement: passo 2, immagine 1 di 1
    • Lift the panel up and then out to gain access to the battery.
  3. Sony Vaio PCG-F360 Optical Drive Replacement: passo 3, immagine 1 di 1
    • Use the indentations to pull the old battery out.
  4. Sony Vaio PCG-F360 Optical Drive Replacement: passo 4, immagine 1 di 1
    • The battery is now removed and it is safe to move on to uninstalling other components.
  5. Sony Vaio PCG-F360 Optical Drive Replacement, Keyboard: passo 5, immagine 1 di 3 Sony Vaio PCG-F360 Optical Drive Replacement, Keyboard: passo 5, immagine 2 di 3 Sony Vaio PCG-F360 Optical Drive Replacement, Keyboard: passo 5, immagine 3 di 3
    • There are two screws on the left hand side of the laptop near the IR (Infared remote) receiver (see image). Remove them using a Phillips #00 Screwdriver.
    • Slide the speaker panel towards the left, then carefully flip it over onto the keyboard.
    • Make sure not to pull the speaker panel away from the computer just yet - it is still connected!
  6. Sony Vaio PCG-F360 Optical Drive Replacement: passo 6, immagine 1 di 3 Sony Vaio PCG-F360 Optical Drive Replacement: passo 6, immagine 2 di 3 Sony Vaio PCG-F360 Optical Drive Replacement: passo 6, immagine 3 di 3
    • On the inside of the speaker panel, using a spudger, push the beige tab in the direction of the ribbon. It should only move a small amount.
    • Remove the ribbon by gently pulling on it, there should be little or no resistance.
    • Now the speaker panel can be set aside.
  7. Sony Vaio PCG-F360 Optical Drive Replacement: passo 7, immagine 1 di 2 Sony Vaio PCG-F360 Optical Drive Replacement: passo 7, immagine 2 di 2
    • Remove the metal screw that will be located at the red circle.
    • Pull on the green strip, and the keyboard should come free easily.
  8. Sony Vaio PCG-F360 Optical Drive Replacement, Optical Drive: passo 8, immagine 1 di 2 Sony Vaio PCG-F360 Optical Drive Replacement, Optical Drive: passo 8, immagine 2 di 2
    • Remove the three screws surrounding the fan.
    • Take off the guard that you just unscrewed.
    • Carefully flip over the heat pipe and the metal sheet connected to it.
  9. Sony Vaio PCG-F360 Optical Drive Replacement: passo 9, immagine 1 di 3 Sony Vaio PCG-F360 Optical Drive Replacement: passo 9, immagine 2 di 3 Sony Vaio PCG-F360 Optical Drive Replacement: passo 9, immagine 3 di 3
    • Remove the three screws from the heat tube cover.
    • Carefully remove the cover.
  10. Sony Vaio PCG-F360 Optical Drive Replacement: passo 10, immagine 1 di 2 Sony Vaio PCG-F360 Optical Drive Replacement: passo 10, immagine 2 di 2
    • Use a spudger to pry the ribbon connected to the optical drive.
    • Slide the optical drive free of the enclosure.
Conclusione
ahintz
Membro da: 04/21/10
28 Reputazione
8 Guide realizzate
Cal Poly, Team 16-3, Maness Spring 2010 Membro di Cal Poly, Team 16-3, Maness Spring 2010
CPSU-MANESS-S10S16G3
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,796
