Salta al contenuto principale
Sony Vaio PCG-F360 Floppy Drive Replacement
  1. Sony Vaio PCG-F360 Floppy Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Position the laptop screen-side down as shown.
    • In this position the battery housing will be located on the right hand side.
  2. Sony Vaio PCG-F360 Floppy Drive Replacement: passo 2, immagine 1 di 1
    • Lift the panel up and then out to gain access to the battery.
  3. Sony Vaio PCG-F360 Floppy Drive Replacement: passo 3, immagine 1 di 1
    • Use the indentations to pull the old battery out.
  4. Sony Vaio PCG-F360 Floppy Drive Replacement: passo 4, immagine 1 di 1
    • The battery is now removed and it is safe to move on to uninstalling other components.
  5. Sony Vaio PCG-F360 Floppy Drive Replacement, Floppy Drive: passo 5, immagine 1 di 2 Sony Vaio PCG-F360 Floppy Drive Replacement, Floppy Drive: passo 5, immagine 2 di 2
    • With one hand slide and hold the tab shown.
    • With your other hand, pull the floppy drive out of the floppy drive bay.
    • To replace the floppy drive, simply slide the drive into the slot until it clicks.
Conclusione
ahintz
Membro da: 04/21/10
28 Reputazione
8 Guide realizzate
Cal Poly, Team 16-3, Maness Spring 2010 Membro di Cal Poly, Team 16-3, Maness Spring 2010
CPSU-MANESS-S10S16G3
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,759
