Salta al contenuto principale
Sony Vaio PCG-981L Clock battery Replacement
Cosa ti serve
  1. Sony Vaio PCG-981L Clock battery Replacement, Clock Battery: passo 1, immagine 1 di 1
    • Place the computer on a flat surface.
  2. Sony Vaio PCG-981L Clock battery Replacement: passo 2, immagine 1 di 2 Sony Vaio PCG-981L Clock battery Replacement: passo 2, immagine 2 di 2
    • Flip your computer upside down.
    • Use a Phillips #1 screwdriver to remove the single screw securing the cover.
  3. Sony Vaio PCG-981L Clock battery Replacement: passo 3, immagine 1 di 1
    • Remove the capsule cover to reveal the computer chip.
  4. Sony Vaio PCG-981L Clock battery Replacement: passo 4, immagine 1 di 1
    • After removing the cover, identify the two screws holding the computer chip in place.
    • Use a Phillips #1 screwdriver to remove the two screws that secure the computer chip by turning your screwdriver counterclockwise.
  5. Sony Vaio PCG-981L Clock battery Replacement: passo 5, immagine 1 di 1
    • Carefully remove the computer chip and set it aside.
  6. Sony Vaio PCG-981L Clock battery Replacement: passo 6, immagine 1 di 1
    • Using your thumb or index finger, locate the clock battery on the upper part of the capsule.
    • Apply pressure to the clock battery until it pops out and remove it from your computer.
  7. Sony Vaio PCG-981L Clock battery Replacement: passo 7, immagine 1 di 1
    • Push your new clock battery into place using your thumb or index finger at the same place where you removed the old clock battery.
  8. Sony Vaio PCG-981L Clock battery Replacement: passo 8, immagine 1 di 1
    • Carefully replace the computer chip and secure the two screws using your Phillips #1 screwdriver by turning the screwdriver clockwise.
  9. Sony Vaio PCG-981L Clock battery Replacement: passo 9, immagine 1 di 1
    • Secure the capsule cover with the screw the same way.
  10. Sony Vaio PCG-981L Clock battery Replacement: passo 10, immagine 1 di 1
    • Flip your computer right side up and turn it on to make sure everything is functioning properly.
Conclusione
If your computer does not function properly after you have completed this guide, please review the guide to see if you missed a step. If not, contact your computer manufacturer for assistance.
Cal Poly, Team 18-68, Johann Spring 2010 Membro di Cal Poly, Team 18-68, Johann Spring 2010
CPSU-JOHANN-S10S18G68
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 22
Tutti i Tempi: 4,812
