Salta al contenuto principale
Sony Vaio PCG-981L Battery Replacement
  1. Sony Vaio PCG-981L Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Before starting, be sure the device is turned off and disconnected from any power cords.
    • Place the device on a flat surface.
  2. Sony Vaio PCG-981L Battery Replacement: passo 2, immagine 1 di 1
    • Rotate the device 90° counterclockwise until the battery cover is in front of you.
    • The battery cover is located in the lower right side of the device in this new orientation.
  3. Sony Vaio PCG-981L Battery Replacement: passo 3, immagine 1 di 1
    • Flip the laptop over so that the bottom is facing up but the battery cover is still facing you.
    • In this new orientation, the battery cover is located on the left side.
  4. Sony Vaio PCG-981L Battery Replacement: passo 4, immagine 1 di 1
    • To remove the battery cover, use your hands to slide it upwards.
  5. Sony Vaio PCG-981L Battery Replacement: passo 5, immagine 1 di 3 Sony Vaio PCG-981L Battery Replacement: passo 5, immagine 2 di 3 Sony Vaio PCG-981L Battery Replacement: passo 5, immagine 3 di 3
    • Once lifted, the battery cover should flip open.
    • Now, carefully remove the battery from the device.
  6. Sony Vaio PCG-981L Battery Replacement: passo 6, immagine 1 di 2 Sony Vaio PCG-981L Battery Replacement: passo 6, immagine 2 di 2
    • Now, the battery should be completely removed from the device.
    • Be sure to dispose of the old battery properly and then you are finished.
Conclusione
Enjoy your new battery.
Cal Poly, Team 18-68, Johann Spring 2010 Membro di Cal Poly, Team 18-68, Johann Spring 2010
CPSU-JOHANN-S10S18G68
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 3,829
