Introduzione
The network card is what allows a laptop to connect to the internet. Replacing a faulty network card can solve connectivity issues. Please review the Troubleshooting Guide before replacing the Network Drive
Parti
Nessuna parte richiesta.
Power off the laptop.
  • Power off the laptop.
  • Unplug the charging cable and any other cables plugged into the laptop.
  • Failure to remove or unplug any cables could result in electric shock.
  • Turn the laptop over so that the back panel is facing upwards.
Aggiungi Commento
Locate two switches above the battery that lock it into place.
  • Locate two switches above the battery that lock it into place.
  • Push the left-hand switch, that says "lock" above it, so that it is unlocked.
Aggiungi Commento
  • Push and hold the right-hand switch, which says "release" above it, and lift the battery up out of its place.
Aggiungi Commento
  • Locate and unscrew the two highlighted 8 mm Phillips #1 screws.
  • There will be three dots next to the desired screws
Aggiungi Commento
  • Grip the cover of the optical drive and slide it out.
  • If it does not come out, do not force it. Double check to make sure the screws are entirely removed.
Aggiungi Commento
  • Remove all the 8mm Phillips #1 screws on the backside of the laptop.
  • There are three 3mm and two 5.3mm screws under the battery that also need to be taken out.
  • There are three 3mm screws under the optical drives that also need to be taken out.
  • Remove the RAM panel in addition to the other screws. For further instructions, refer to the RAM replacement guide.
Aggiungi Commento
  • Pry along the edges of the back panel using the spudger.
  • If you are struggling to remove the back panel with a moderate amount of force, do NOT apply any additional force, instead double check to make sure all the screws were removed before attempting again.
Aggiungi Commento
  • Pull the two cables off of the network card.
  • Make sure to pull the cables straight up as the connectors are fragile.
Aggiungi Commento
  • Remove the two Phillips 5.3mm screws from the network card.
  • After the screws are released, the network chip should lift up at an angle.
  • Gently pull out the network card.
Aggiungi Commento
Conclusione
Sid
Membro da: 18/05/2014
284 Reputazione
2 Guide realizzate
Cal Poly, Team 9-17, Regan Spring 2014 Membro di Cal Poly, Team 9-17, Regan Spring 2014
CPSU-REGAN-S14S9G17
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,522
