Introduzione
The battery of the Vaio PCG-7184L is on the underside on the laptop. The removal of the battery is an important step that should be taken for any other repair, displacement, or dis-assembly.
Power off the laptop.
  • Power off the laptop.
  • Unplug the charging cable and any other cables plugged into the laptop.
  • Failure to remove or unplug any cables could result in electric shock.
  • Turn the laptop over so that the back panel is facing upwards.
Aggiungi Commento
Locate two switches above the battery that lock it into place.
  • Locate two switches above the battery that lock it into place.
  • Push the left-hand switch, that says "lock" above it, so that it is unlocked.
Aggiungi Commento
  • Push and hold the right-hand switch, which says "release" above it, and lift the battery up out of its place.
Aggiungi Commento
Conclusione
To reassemble your battery, line up the battery and slide it in until the second lock (left hand switch) clicks. Then lock the 1st switch.
Brian Luu
Membro da: 08/04/2014
503 Reputazione
3 Guide realizzate
Cal Poly, Team 9-17, Regan Spring 2014 Membro di Cal Poly, Team 9-17, Regan Spring 2014
CPSU-REGAN-S14S9G17
4 Membri
9 Guide realizzate
How to test my battery performance Sony VAIO
Pcg- 7184L
Ramesh C - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 30
Tutti i Tempi: 2,058
