Salta al contenuto principale
Sony Vaio VGN-NW240F (PCG-7184L) Battery Replacement
  1. Sony Vaio VGN-NW240F (PCG-7184L) Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Power off the laptop.
    • Unplug the charging cable and any other cables plugged into the laptop.
    • Failure to remove or unplug any cables could result in electric shock.
    • Turn the laptop over so that the back panel is facing upwards.
  2. Sony Vaio VGN-NW240F (PCG-7184L) Battery Replacement: passo 2, immagine 1 di 1
    • Locate two switches above the battery that lock it into place.
    • Push the left-hand switch, that says "lock" above it, so that it is unlocked.
  3. Sony Vaio VGN-NW240F (PCG-7184L) Battery Replacement: passo 3, immagine 1 di 1
    • Push and hold the right-hand switch, which says "release" above it, and lift the battery up out of its place.
Conclusione
To reassemble your battery, line up the battery and slide it in until the second lock (left hand switch) clicks. Then lock the 1st switch.
Altre 4 persone hanno completato questa guida.
Brian Luu
Membro da: 04/08/14
720 Reputazione
3 Guide realizzate
Cal Poly, Team 9-17, Regan Spring 2014 Membro di Cal Poly, Team 9-17, Regan Spring 2014
CPSU-REGAN-S14S9G17
4 Membri
18 Guide realizzate
Un commento
How to test my battery performance Sony VAIO
Pcg- 7184L
Ramesh C - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 22
Tutti i Tempi: 3,264
