Salta al contenuto principale
Sony Vaio VGN-SZ120P Hard Drive Replacement
Cosa ti serve
  1. Sony Vaio VGN-SZ120P Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Set the computer display-side down.
    • Unlock the battery by sliding the port-side latch to the 'unlock' position.
  2. Sony Vaio VGN-SZ120P Hard Drive Replacement: passo 2, immagine 1 di 1
    • On the opposite side of the battery, press the release latch and slide the battery away from the main body to remove.
  3. Sony Vaio VGN-SZ120P Hard Drive Replacement, Keyboard: passo 3, immagine 1 di 1
    • Ignore the removal of the heat sink and memory panels as depicted. They do not need to be removed for the completion of this guide.
    • Remove the Torx security screw near the center of the battery-side edge.
  4. Sony Vaio VGN-SZ120P Hard Drive Replacement: passo 4, immagine 1 di 2 Sony Vaio VGN-SZ120P Hard Drive Replacement: passo 4, immagine 2 di 2
    • Press the tabs on each side of the display-side of the keyboard with the flat edge of a spudger.
    • Pull the keyboard toward the mouse pad and gently lift up.
  5. Sony Vaio VGN-SZ120P Hard Drive Replacement: passo 5, immagine 1 di 2 Sony Vaio VGN-SZ120P Hard Drive Replacement: passo 5, immagine 2 di 2
    • The keyboard is still attached by ribbon cable, don't try to remove the keyboard entirely yet.
    • Disconnect the ribbon cable by pressing the tabs on either side of the connector. Pull the cable out parallel to the connector.
    • Remove the keyboard.
  6. Sony Vaio VGN-SZ120P Hard Drive Replacement, Mouse Assembly: passo 6, immagine 1 di 1
    • Turn the laptop upside down.
    • Remove the three screws from the front mouse panel located on the bottom of the laptop.
    • Carefully flip the laptop back over. Remove three more screws from the top securing the panel. A ribbon cable will still be attached to the panel when you remove it.
  7. Sony Vaio VGN-SZ120P Hard Drive Replacement: passo 7, immagine 1 di 2 Sony Vaio VGN-SZ120P Hard Drive Replacement: passo 7, immagine 2 di 2
    • Lift the mouse assembly just enough to access the connecting ribbon cable.
    • Lift the ribbon cable lock to remove the cable.
    • Carefully remove the mouse panel assembly and set aside.
  8. Sony Vaio VGN-SZ120P Hard Drive Replacement, Hard Drive: passo 8, immagine 1 di 1
    • This is where your hard drive would be located. The replacement must be a Serial ATA(SATA) hard drive
    • Remove the four hard drive securing screws.
Conclusione
Altre 20 persone hanno completato questa guida.
Cal Poly, Team 25-89, Amido Spring 2010 Membro di Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Membri
63 Guide realizzate
3 Commenti
simple and perfect in every detail
francesco - Replica
como le cambio la pantalla a esta lap
Armand San - Replica
como le puedo cambiar el monitor a este modelo
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 31
Tutti i Tempi: 40,148
