Salta al contenuto principale
Sony Vaio VPCEG26FX Back Panel Replacement
Cosa ti serve
  1. Sony Vaio VPCEG26FX Back Panel Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop so the bottom is facing up with the model number visible.
  2. Sony Vaio VPCEG26FX Back Panel Replacement: passo 2, immagine 1 di 2 Sony Vaio VPCEG26FX Back Panel Replacement: passo 2, immagine 2 di 2
    • Slide the lock switch down until you hear a click to unlock the battery.
  3. Sony Vaio VPCEG26FX Back Panel Replacement: passo 3, immagine 1 di 2 Sony Vaio VPCEG26FX Back Panel Replacement: passo 3, immagine 2 di 2
    • Slide the release slider up and simultaneously push the battery upwards away from the device until it falls out of place.
  4. Sony Vaio VPCEG26FX Back Panel Replacement: passo 4, immagine 1 di 2 Sony Vaio VPCEG26FX Back Panel Replacement: passo 4, immagine 2 di 2
    • Remove the battery from the battery compartment.
  5. Sony Vaio VPCEG26FX Back Panel Replacement, Hard Drive: passo 5, immagine 1 di 1
    • Loosen the two (7mm) screws that hold the hard drive panel in place with a JIS #0 screwdriver.
    • These screws cannot be removed.
  6. Sony Vaio VPCEG26FX Back Panel Replacement: passo 6, immagine 1 di 1
    • Remove the plastic and unscrew the screw on the hard drive using the JIS #0 screwdriver.
  7. Sony Vaio VPCEG26FX Back Panel Replacement: passo 7, immagine 1 di 1
    • Push the hard drive towards the optical reader to unlock it.
  8. Sony Vaio VPCEG26FX Back Panel Replacement: passo 8, immagine 1 di 1
    • Remove the hard drive from the device.
  9. Sony Vaio VPCEG26FX Back Panel Replacement, RAM: passo 9, immagine 1 di 1
    • After you remove the battery, there is a small rectangular panel underneath where the battery was housed.
  10. Sony Vaio VPCEG26FX Back Panel Replacement: passo 10, immagine 1 di 1
    • Remove the single screw holding the panel in place using the JIS #0 screwdriver.
  11. Sony Vaio VPCEG26FX Back Panel Replacement: passo 11, immagine 1 di 3 Sony Vaio VPCEG26FX Back Panel Replacement: passo 11, immagine 2 di 3 Sony Vaio VPCEG26FX Back Panel Replacement: passo 11, immagine 3 di 3
    • Remove the green circuit board by dislodging the circuit it is attached to.
    • Unhook it and remove it from the device.
  12. Sony Vaio VPCEG26FX Back Panel Replacement, Back Panel: passo 12, immagine 1 di 1
    • Remove the remaining eleven 7mm screws from back panel using the JIS #0 screwdriver.
  13. Sony Vaio VPCEG26FX Back Panel Replacement: passo 13, immagine 1 di 2 Sony Vaio VPCEG26FX Back Panel Replacement: passo 13, immagine 2 di 2
    • Remove the back panel from the device.
Conclusione
Sara Alfaro
Membro da: 03/08/19
531 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 892
