Salta al contenuto principale
Sony Vaio PCG-61411L Hard Drive Replacement
Cosa ti serve
  1. Sony Vaio PCG-61411L Hard Drive Replacement, Battery: passo 1, immagine 1 di 3 Sony Vaio PCG-61411L Hard Drive Replacement, Battery: passo 1, immagine 2 di 3 Sony Vaio PCG-61411L Hard Drive Replacement, Battery: passo 1, immagine 3 di 3
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Sony Vaio PCG-61411L Hard Drive Replacement: passo 2, immagine 1 di 3 Sony Vaio PCG-61411L Hard Drive Replacement: passo 2, immagine 2 di 3 Sony Vaio PCG-61411L Hard Drive Replacement: passo 2, immagine 3 di 3
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
  3. Sony Vaio PCG-61411L Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 1
    • The hard drive panel is located in the bottom right corner of the device.
  4. Sony Vaio PCG-61411L Hard Drive Replacement: passo 4, immagine 1 di 2 Sony Vaio PCG-61411L Hard Drive Replacement: passo 4, immagine 2 di 2
    • Using the PH #0 screwdriver, unscrew the two 6.5mm screws located in the bottom left and middle right of the panel. The screws remain in the panels.
    • Remove the panel by pulling it up towards yourself.
  5. Sony Vaio PCG-61411L Hard Drive Replacement: passo 5, immagine 1 di 3 Sony Vaio PCG-61411L Hard Drive Replacement: passo 5, immagine 2 di 3 Sony Vaio PCG-61411L Hard Drive Replacement: passo 5, immagine 3 di 3
    • Using a PH0 screwdriver, remove the four 3mm silver screws located in the external hard drive cover.
    • Using a PH00 screwdriver, remove the final 3mm black screw located in the top right section of the hard drive cover.
    • Carefully remove the silver hard drive cover.
  6. Sony Vaio PCG-61411L Hard Drive Replacement: passo 6, immagine 1 di 3 Sony Vaio PCG-61411L Hard Drive Replacement: passo 6, immagine 2 di 3 Sony Vaio PCG-61411L Hard Drive Replacement: passo 6, immagine 3 di 3
    • Detach the hard drive by disconnecting it from the motherboard, pulling it gently from left to right.
Conclusione
Sean Lyon
Membro da: 03/01/18
381 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,587
