Salta al contenuto principale
Sony Vaio VPCEA3C5E Key Replacement
Cosa ti serve
  1. Sony Vaio VPCEA3C5E Key Replacement, Key: passo 1, immagine 1 di 1
    • Use a pair of tweezers like the one shown in the picture.
  2. Sony Vaio VPCEA3C5E Key Replacement: passo 2, immagine 1 di 1
    • Use the tweezers to get under the key piece on the keyboard as shown in the picture.
  3. Sony Vaio VPCEA3C5E Key Replacement: passo 3, immagine 1 di 1
    • Carefully lift the key piece upward to remove it completely.
  4. Sony Vaio VPCEA3C5E Key Replacement: passo 4, immagine 1 di 1
    • After the key is removed, you should be able to see the part underneath the key where it can be replaced.
Conclusione
To reassemble your device, follow these instructions carefully in reverse order.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 26
Tutti i Tempi: 918
