Salta al contenuto principale
Sony Vaio VPCCW17FX Webcam Replacement
Cosa ti serve
  1. Sony Vaio VPCCW17FX Webcam Replacement, Webcam: passo 1, immagine 1 di 1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Webcam Replacement: passo 2, immagine 1 di 1
    • Slide both latches to the center of the laptop in order to release the battery.
  3. Sony Vaio VPCCW17FX Webcam Replacement: passo 3, immagine 1 di 2 Sony Vaio VPCCW17FX Webcam Replacement: passo 3, immagine 2 di 2
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX Webcam Replacement: passo 4, immagine 1 di 2 Sony Vaio VPCCW17FX Webcam Replacement: passo 4, immagine 2 di 2
    • Remove the four rubber circles using the spudger located on each corner of the laptop.
    • Remove the four screws (Length: 7.7 mm) using the Phillips #0 screwdriver that are located under each rubber circle.
  5. Sony Vaio VPCCW17FX Webcam Replacement: passo 5, immagine 1 di 2 Sony Vaio VPCCW17FX Webcam Replacement: passo 5, immagine 2 di 2
    • Slowly peel off the plastic covering around the screen.
    • Place it to the side once it is completely disconnected.
    • You may need to apply slight pressure to release the clips of the covering.
  6. Sony Vaio VPCCW17FX Webcam Replacement: passo 6, immagine 1 di 3 Sony Vaio VPCCW17FX Webcam Replacement: passo 6, immagine 2 di 3 Sony Vaio VPCCW17FX Webcam Replacement: passo 6, immagine 3 di 3
    • Remove the two screws (Length: 7.7 mm) using the Phillips #0 screwdriver that hold the Webcam in place.
    • Gently pull the webcam away from the laptop.
    • Slowly disconnect the two ribbon cable connectors by sliding them towards the wire to disconnect the webcam from the laptop.
Conclusione
Tiffani Beck
Membro da: 03/20/17
219 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,098
