Salta al contenuto principale
Sony Vaio VGN-SR140E Screen Replacement
Cosa ti serve
  1. Sony Vaio VGN-SR140E Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E Screen Replacement: passo 2, immagine 1 di 1
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E Screen Replacement: passo 3, immagine 1 di 2 Sony Vaio VGN-SR140E Screen Replacement: passo 3, immagine 2 di 2
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E Screen Replacement, Screen: passo 4, immagine 1 di 3 Sony Vaio VGN-SR140E Screen Replacement, Screen: passo 4, immagine 2 di 3 Sony Vaio VGN-SR140E Screen Replacement, Screen: passo 4, immagine 3 di 3
    • Remove the rubber pads at all four corners of the screen bezel using a spudger. This will reveal four 5mm Phillips screws.
    • Use a Phillips #1 screwdriver to remove the four screws and set them aside.
  5. Sony Vaio VGN-SR140E Screen Replacement: passo 5, immagine 1 di 1
    • Remove the screen's plastic bezel. You may need to use slight pressure to release the clips that secure the bezel to the laptop.
  6. Sony Vaio VGN-SR140E Screen Replacement: passo 6, immagine 1 di 2 Sony Vaio VGN-SR140E Screen Replacement: passo 6, immagine 2 di 2
    • Lift screen bezel up and off of the laptop.
  7. Sony Vaio VGN-SR140E Screen Replacement: passo 7, immagine 1 di 3 Sony Vaio VGN-SR140E Screen Replacement: passo 7, immagine 2 di 3 Sony Vaio VGN-SR140E Screen Replacement: passo 7, immagine 3 di 3
    • Close the laptop carefully and slowly while holding the screen with your thumb to prevent it from falling.
    • Lay the screen gently on the keyboard. This will reveal the screen's connector.
  8. Sony Vaio VGN-SR140E Screen Replacement: passo 8, immagine 1 di 3 Sony Vaio VGN-SR140E Screen Replacement: passo 8, immagine 2 di 3 Sony Vaio VGN-SR140E Screen Replacement: passo 8, immagine 3 di 3
    • Grasp the connector and gently pull it out.
  9. Sony Vaio VGN-SR140E Screen Replacement: passo 9, immagine 1 di 1
    • The screen can now be removed.
Conclusione
Jeremy
Membro da: 03/18/15
722 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,120
