Salta al contenuto principale
Sony Vaio VPC-Y2190X RAM Card Replacement
Cosa ti serve
  1. Sony Vaio VPC-Y2190X RAM Card Replacement, Battery: passo 1, immagine 1 di 1
    • Flip your laptop so that the bottom is facing up.
  2. Sony Vaio VPC-Y2190X RAM Card Replacement: passo 2, immagine 1 di 1
    • Slide the “Lock” switch to the right.
    • Slide and hold the “Release” switch to the left.
  3. Sony Vaio VPC-Y2190X RAM Card Replacement: passo 3, immagine 1 di 2 Sony Vaio VPC-Y2190X RAM Card Replacement: passo 3, immagine 2 di 2
    • While holding the “Release” switch, lift the lip of the battery.
    • Lift the battery up and out of the laptop.
  4. Sony Vaio VPC-Y2190X RAM Card Replacement, RAM Card: passo 4, immagine 1 di 2 Sony Vaio VPC-Y2190X RAM Card Replacement, RAM Card: passo 4, immagine 2 di 2
    • Use a #0PH screwdriver to unscrew the three 4.80mm screws.
    • Remove the panel.
  5. Sony Vaio VPC-Y2190X RAM Card Replacement: passo 5, immagine 1 di 1
    • Pull the metal tabs in opposite directions, away from the RAM card.
    • The RAM card will swing upwards.
  6. Sony Vaio VPC-Y2190X RAM Card Replacement: passo 6, immagine 1 di 1
    • Grab the RAM card from its center.
    • Gently pull the RAM card out.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 318
