Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Parti
Nessuna parte specificata.
  1. Take out the screw in the center of the computer.
    • Take out the screw in the center of the computer.
  2. Flip the computer right side up.
    • Flip the computer right side up.
    • Open screen so that keyboard is visible.
  3. Use a plastic opening tool to gently lift the keyboard at a corner. Make sure you get below the keyboard itself and not just the keys.
    • Use a plastic opening tool to gently lift the keyboard at a corner.
    • Make sure you get below the keyboard itself and not just the keys.
    • Slide the tool around the perimeter of the keyboard and it will start to lift.
  4. Do not pull the keyboard away from the computer. There is a ribbon cord attaching the keyboard to the computer. Once the keyboard has been lifted at a few edges, lift the keyboard with both hands.
    • Do not pull the keyboard away from the computer. There is a ribbon cord attaching the keyboard to the computer.
    • Once the keyboard has been lifted at a few edges, lift the keyboard with both hands.
  5. Locate the ribbon cord behind the keyboard. Locate a brown clamp attaching the keyboard to the computer. Use a plastic opening tool to lift the clamp and release the cable.
    • Locate the ribbon cord behind the keyboard.
    • Locate a brown clamp attaching the keyboard to the computer.
    • Use a plastic opening tool to lift the clamp and release the cable.
    • Now the keyboard can be pulled away entirely.
Conclusione
Austen
Membro da: 03/04/2012
32 Reputazione
2 Guide realizzate
Cal Poly, Team 5-3, Forte Spring 2012 Membro di Cal Poly, Team 5-3, Forte Spring 2012
CPSU-FORTE-S12S5G3
5 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,845
