Salta al contenuto principale
Sony Vaio VGN-TXN25N Display Screen Replacement
Cosa ti serve
  1. Sony Vaio VGN-TXN25N Display Screen Replacement, Display Screen: passo 1, immagine 1 di 2 Sony Vaio VGN-TXN25N Display Screen Replacement, Display Screen: passo 1, immagine 2 di 2
    • Place the computer on a flat surface with the top facing up.
    • Open the screen.
  2. Sony Vaio VGN-TXN25N Display Screen Replacement: passo 2, immagine 1 di 3 Sony Vaio VGN-TXN25N Display Screen Replacement: passo 2, immagine 2 di 3 Sony Vaio VGN-TXN25N Display Screen Replacement: passo 2, immagine 3 di 3
    • Locate the rubber screw caps at the two bottom corners of the screen.
    • Use your finger to remove the rubber screw caps.
  3. Sony Vaio VGN-TXN25N Display Screen Replacement: passo 3, immagine 1 di 2 Sony Vaio VGN-TXN25N Display Screen Replacement: passo 3, immagine 2 di 2
    • Locate the two screws, one on each bottom corner.
    • Unscrew the screws with a Phillips head size #0 screwdriver.
    • Keep track of the screws. They are small and easy to misplace.
  4. Sony Vaio VGN-TXN25N Display Screen Replacement: passo 4, immagine 1 di 3 Sony Vaio VGN-TXN25N Display Screen Replacement: passo 4, immagine 2 di 3 Sony Vaio VGN-TXN25N Display Screen Replacement: passo 4, immagine 3 di 3
    • Use a plastic opening tool to gently lift the plastic casing that borders the screen.
    • Pop off the casing by working the tool around the outside of it.
    • Wiggling the tool may be required. The casing could be fitted snugly.
  5. Sony Vaio VGN-TXN25N Display Screen Replacement: passo 5, immagine 1 di 3 Sony Vaio VGN-TXN25N Display Screen Replacement: passo 5, immagine 2 di 3 Sony Vaio VGN-TXN25N Display Screen Replacement: passo 5, immagine 3 di 3
    • Carefully flip down the screen so it rests on the keyboard.
    • Locate the wire connector on the back of the screen and use a plastic opening tool to gently loosen the wire connection.
  6. Sony Vaio VGN-TXN25N Display Screen Replacement: passo 6, immagine 1 di 1
    • Remove the screen.
Conclusione
Cal Poly, Team 5-3, Forte Spring 2012 Membro di Cal Poly, Team 5-3, Forte Spring 2012
CPSU-FORTE-S12S5G3
5 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 12
Tutti i Tempi: 3,582
