Salta al contenuto principale
Sony Vaio PCG-4G1L Optical Drive Replacement
Cosa ti serve
  1. Sony Vaio PCG-4G1L Optical Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off the computer and disconnect the charging cable.
    • Failing to unplug the cable can result in electric shock.
  2. Sony Vaio PCG-4G1L Optical Drive Replacement: passo 2, immagine 1 di 2 Sony Vaio PCG-4G1L Optical Drive Replacement: passo 2, immagine 2 di 2
    • Slide battery release toggle switch towards the "RELEASE" print.
  3. Sony Vaio PCG-4G1L Optical Drive Replacement: passo 3, immagine 1 di 3 Sony Vaio PCG-4G1L Optical Drive Replacement: passo 3, immagine 2 di 3 Sony Vaio PCG-4G1L Optical Drive Replacement: passo 3, immagine 3 di 3
    • Apply pressure with your thumb on the grip.
    • Pull the battery out while simultaneously holding the battery release toggle switch in the release position.
  4. Sony Vaio PCG-4G1L Optical Drive Replacement, Keyboard: passo 4, immagine 1 di 2 Sony Vaio PCG-4G1L Optical Drive Replacement, Keyboard: passo 4, immagine 2 di 2
    • Remove one 5 mm Phillips #1 pan head screw, in the middle of the laptop, using a Bit Driver with Phillips PH1 bit.
  5. Sony Vaio PCG-4G1L Optical Drive Replacement: passo 5, immagine 1 di 2 Sony Vaio PCG-4G1L Optical Drive Replacement: passo 5, immagine 2 di 2
    • Be sure to pry the plastic opening tool under the keyboard, rather than under the keys. Otherwise, some keys could get harmed.
    • While using a plastic opening tool, carefully lift the keyboard by inserting the tool under the edge.
  6. Sony Vaio PCG-4G1L Optical Drive Replacement: passo 6, immagine 1 di 3 Sony Vaio PCG-4G1L Optical Drive Replacement: passo 6, immagine 2 di 3 Sony Vaio PCG-4G1L Optical Drive Replacement: passo 6, immagine 3 di 3
    • Do not pull the keyboard too far away, as a ribbon cable is still attached. Failing to do so can cause damage to the ribbon cable or the connector.
    • Use the plastic opening tool to release the clamp.
    • Using slight pressure, remove the ribbon cable with your fingers.
  7. Sony Vaio PCG-4G1L Optical Drive Replacement, Network Antenna: passo 7, immagine 1 di 1
    • Swivel the Network Antenna up so that it points upward.
  8. Sony Vaio PCG-4G1L Optical Drive Replacement: passo 8, immagine 1 di 2 Sony Vaio PCG-4G1L Optical Drive Replacement: passo 8, immagine 2 di 2
    • Pinch thumb and index finger at the Network Antenna's base.
    • Make sure not to bend the Network Antenna. Failing to do so can cause damage to the antenna.
    • Pull the Network Antenna off.
  9. Sony Vaio PCG-4G1L Optical Drive Replacement, Plastic Casing: passo 9, immagine 1 di 2 Sony Vaio PCG-4G1L Optical Drive Replacement, Plastic Casing: passo 9, immagine 2 di 2
    • Remove seven 5 mm Phillips #1 pan head screws with a Bit Driver, using a Phillips PH1 bit.
  10. Sony Vaio PCG-4G1L Optical Drive Replacement: passo 10, immagine 1 di 2 Sony Vaio PCG-4G1L Optical Drive Replacement: passo 10, immagine 2 di 2
    • Remove one 7 mm Phillips #1 Pan Head Screw by using a Bit Driver with Phillips PH1 bit.
  11. Sony Vaio PCG-4G1L Optical Drive Replacement: passo 11, immagine 1 di 2 Sony Vaio PCG-4G1L Optical Drive Replacement: passo 11, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Disconnect the cable by using the precision tweezers.
    • Slowly pry out the ribbon cable by using the plastic opening tool.
  12. Sony Vaio PCG-4G1L Optical Drive Replacement: passo 12, immagine 1 di 1
    • Do not pull the plastic cover too far away, as a ribbon cable is still attached. Failing to do so can cause damage to ribbon cable or the connector.
    • Remove the plastic cover by inserting the plastic opening tool around the edge.
  13. Sony Vaio PCG-4G1L Optical Drive Replacement: passo 13, immagine 1 di 2 Sony Vaio PCG-4G1L Optical Drive Replacement: passo 13, immagine 2 di 2
    • Disconnect the ribbon cable by pulling straight up with your fingers.
  14. Sony Vaio PCG-4G1L Optical Drive Replacement, Optical Drive: passo 14, immagine 1 di 2 Sony Vaio PCG-4G1L Optical Drive Replacement, Optical Drive: passo 14, immagine 2 di 2
    • Insert the PH0.8 bit into the pin hole to eject the optical drive.
  15. Sony Vaio PCG-4G1L Optical Drive Replacement: passo 15, immagine 1 di 2 Sony Vaio PCG-4G1L Optical Drive Replacement: passo 15, immagine 2 di 2
    • Remove one 4mm Phillips #0 pan head screw, using a Bit Driver with a Phillips PH000 bit.
    • Remove three 5mm Phillips #0 flat head screws, using a Bit Driver with a Phillips PH000 bit.
  16. Sony Vaio PCG-4G1L Optical Drive Replacement: passo 16, immagine 1 di 2 Sony Vaio PCG-4G1L Optical Drive Replacement: passo 16, immagine 2 di 2
    • Apply pressure to the ribbon cable, then pick up and pull the optical drive away from the cable.
Conclusione
Cole Collins
Membro da: 10/04/16
193 Reputazione
4 Guide realizzate
USF Tampa, Team 2-3, Cagle Fall 2016 Membro di USF Tampa, Team 2-3, Cagle Fall 2016
USFT-CAGLE-F16S2G3
5 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 614
