Salta al contenuto principale
Sony Vaio PCG-41216L Network Card Replacement
Cosa ti serve
  1. Sony Vaio PCG-41216L Network Card Replacement, Network Card: passo 1, immagine 1 di 2 Sony Vaio PCG-41216L Network Card Replacement, Network Card: passo 1, immagine 2 di 2
    • Flip the laptop over to begin the process.
    • Make sure the laptop is turned off and unplugged from the power cable.
  2. Sony Vaio PCG-41216L Network Card Replacement: passo 2, immagine 1 di 3 Sony Vaio PCG-41216L Network Card Replacement: passo 2, immagine 2 di 3 Sony Vaio PCG-41216L Network Card Replacement: passo 2, immagine 3 di 3
    • Remove the two 7mm Phillips #1 screws holding the battery cover.
  3. Sony Vaio PCG-41216L Network Card Replacement: passo 3, immagine 1 di 3 Sony Vaio PCG-41216L Network Card Replacement: passo 3, immagine 2 di 3 Sony Vaio PCG-41216L Network Card Replacement: passo 3, immagine 3 di 3
    • Locate the networking card above the hard drive and next to the RAM.
    • Carefully pop out the two connection cables from the networking card.
  4. Sony Vaio PCG-41216L Network Card Replacement: passo 4, immagine 1 di 3 Sony Vaio PCG-41216L Network Card Replacement: passo 4, immagine 2 di 3 Sony Vaio PCG-41216L Network Card Replacement: passo 4, immagine 3 di 3
    • Remove the black tape to uncover the screw underneath.
    • Remove the 3mm Phillips head screw.
    • When loosening the screw, the network card will automatically lift itself to a diagonal position. This is normal.
  5. Sony Vaio PCG-41216L Network Card Replacement: passo 5, immagine 1 di 2 Sony Vaio PCG-41216L Network Card Replacement: passo 5, immagine 2 di 2
    • Pull the network card straight out in the direction it is resting in.
    • Reinsert the new network card diagonally and into the same position as the previous one.
    • To screw the new network card back into place, you will need to push the network card back down onto the motherboard.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 19
Tutti i Tempi: 624
