Salta al contenuto principale
Sony Vaio PCG-3C2L RAM Replacement
Cosa ti serve
  1. Sony Vaio PCG-3C2L RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Turn your computer over so the bottom is facing up.
    • The battery should be in the top on the back of the computer.
  2. Sony Vaio PCG-3C2L RAM Replacement: passo 2, immagine 1 di 2 Sony Vaio PCG-3C2L RAM Replacement: passo 2, immagine 2 di 2
    • Initially, the "lock" button should be pushed all the way to the left. To unlock the battery, move the lock button from the left to the right.
  3. Sony Vaio PCG-3C2L RAM Replacement: passo 3, immagine 1 di 1
    • After unlocking the battery, hold the "release" button and push to the left.
  4. Sony Vaio PCG-3C2L RAM Replacement: passo 4, immagine 1 di 3 Sony Vaio PCG-3C2L RAM Replacement: passo 4, immagine 2 di 3 Sony Vaio PCG-3C2L RAM Replacement: passo 4, immagine 3 di 3
    • Keep the "release" button pressed.
    • Use the iFixit opening tool (or your hands) to lift the battery up.
  5. Sony Vaio PCG-3C2L RAM Replacement, RAM: passo 5, immagine 1 di 1
    • Flip the computer over so the bottom is facing up.
  6. Sony Vaio PCG-3C2L RAM Replacement: passo 6, immagine 1 di 2 Sony Vaio PCG-3C2L RAM Replacement: passo 6, immagine 2 di 2
    • Unscrew the panel screw with a Phillips #0 screwdriver.
    • The screw is captive, it does not get removed from the panel.
    • Remove the panel from the laptop.
  7. Sony Vaio PCG-3C2L RAM Replacement: passo 7, immagine 1 di 3 Sony Vaio PCG-3C2L RAM Replacement: passo 7, immagine 2 di 3 Sony Vaio PCG-3C2L RAM Replacement: passo 7, immagine 3 di 3
    • Inside the panel there will be two green panels with black rectangles on top. This is the RAM.
    • To remove the RAM, use your fingers to press the metal tabs on the white holders outwards.
    • At this point, the green panel will flip up slightly.
  8. Sony Vaio PCG-3C2L RAM Replacement: passo 8, immagine 1 di 3 Sony Vaio PCG-3C2L RAM Replacement: passo 8, immagine 2 di 3 Sony Vaio PCG-3C2L RAM Replacement: passo 8, immagine 3 di 3
    • With the green panel flipped up, use your hands to remove the RAM.
    • Do the same thing for the second green panel.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,131
