Salta al contenuto principale
Sony Vaio PCG-3C2L Motherboard Replacement
Cosa ti serve
  1. Sony Vaio PCG-3C2L Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Turn your computer over so the bottom is facing up.
    • The battery should be in the top on the back of the computer.
  2. Sony Vaio PCG-3C2L Motherboard Replacement: passo 2, immagine 1 di 2 Sony Vaio PCG-3C2L Motherboard Replacement: passo 2, immagine 2 di 2
    • Initially, the "lock" button should be pushed all the way to the left. To unlock the battery, move the lock button from the left to the right.
  3. Sony Vaio PCG-3C2L Motherboard Replacement: passo 3, immagine 1 di 1
    • After unlocking the battery, hold the "release" button and push to the left.
  4. Sony Vaio PCG-3C2L Motherboard Replacement: passo 4, immagine 1 di 3 Sony Vaio PCG-3C2L Motherboard Replacement: passo 4, immagine 2 di 3 Sony Vaio PCG-3C2L Motherboard Replacement: passo 4, immagine 3 di 3
    • Keep the "release" button pressed.
    • Use the iFixit opening tool (or your hands) to lift the battery up.
  5. Sony Vaio PCG-3C2L Motherboard Replacement, RAM: passo 5, immagine 1 di 1
    • Flip the computer over so the bottom is facing up.
  6. Sony Vaio PCG-3C2L Motherboard Replacement: passo 6, immagine 1 di 2 Sony Vaio PCG-3C2L Motherboard Replacement: passo 6, immagine 2 di 2
    • Unscrew the panel screw with a Phillips #0 screwdriver.
    • The screw is captive, it does not get removed from the panel.
    • Remove the panel from the laptop.
  7. Sony Vaio PCG-3C2L Motherboard Replacement: passo 7, immagine 1 di 3 Sony Vaio PCG-3C2L Motherboard Replacement: passo 7, immagine 2 di 3 Sony Vaio PCG-3C2L Motherboard Replacement: passo 7, immagine 3 di 3
    • Inside the panel there will be two green panels with black rectangles on top. This is the RAM.
    • To remove the RAM, use your fingers to press the metal tabs on the white holders outwards.
    • At this point, the green panel will flip up slightly.
  8. Sony Vaio PCG-3C2L Motherboard Replacement: passo 8, immagine 1 di 3 Sony Vaio PCG-3C2L Motherboard Replacement: passo 8, immagine 2 di 3 Sony Vaio PCG-3C2L Motherboard Replacement: passo 8, immagine 3 di 3
    • With the green panel flipped up, use your hands to remove the RAM.
    • Do the same thing for the second green panel.
  9. Sony Vaio PCG-3C2L Motherboard Replacement, Hard Drive: passo 9, immagine 1 di 1
    • Place the laptop so that the bottom is facing up.
  10. Sony Vaio PCG-3C2L Motherboard Replacement: passo 10, immagine 1 di 1
    • Using a Phillips #0 screwdriver, remove the two 3.5mm screws on the hard drive cover.
  11. Sony Vaio PCG-3C2L Motherboard Replacement: passo 11, immagine 1 di 2 Sony Vaio PCG-3C2L Motherboard Replacement: passo 11, immagine 2 di 2
    • Using a Phillips #0 screwdriver, remove the three 8mm screws on the hard drive casing.
    • Remove the black hard drive casing by pulling it off.
  12. Sony Vaio PCG-3C2L Motherboard Replacement: passo 12, immagine 1 di 3 Sony Vaio PCG-3C2L Motherboard Replacement: passo 12, immagine 2 di 3 Sony Vaio PCG-3C2L Motherboard Replacement: passo 12, immagine 3 di 3
    • Remove the hard drive by carefully sliding it out.
  13. Sony Vaio PCG-3C2L Motherboard Replacement, Fan: passo 13, immagine 1 di 1
    • Remove the six 8 mm edge screws from the back panel using a Phillips #0 screwdriver.
    • Remove the two 8 mm corner screws from the back panel using a Phillips #0 screwdriver.
    • Remove the four 8 mm middle screws from the back panel using a Phillips #0 screwdriver.
    • Remove the three 2 mm screws from the back panel using a Phillips #0 screwdriver.
  14. Sony Vaio PCG-3C2L Motherboard Replacement: passo 14, immagine 1 di 1
    • Remove the 6 mm screw from the battery holder using a Phillips #0 screwdriver.
    • Remove the two 4 mm screws from the battery holder using a Phillips #0 screwdriver.
  15. Sony Vaio PCG-3C2L Motherboard Replacement: passo 15, immagine 1 di 3 Sony Vaio PCG-3C2L Motherboard Replacement: passo 15, immagine 2 di 3 Sony Vaio PCG-3C2L Motherboard Replacement: passo 15, immagine 3 di 3
    • Remove the CD cartridge from the back panel by sliding it out.
  16. Sony Vaio PCG-3C2L Motherboard Replacement: passo 16, immagine 1 di 3 Sony Vaio PCG-3C2L Motherboard Replacement: passo 16, immagine 2 di 3 Sony Vaio PCG-3C2L Motherboard Replacement: passo 16, immagine 3 di 3
    • Using your hands, pull up the back panel about two inches up from the rest of the laptop.
    • Disconnect the black wire connector.
    • Remove back panel.
    • Pull up the back panel slowly so the black wire connector does not break.
  17. Sony Vaio PCG-3C2L Motherboard Replacement: passo 17, immagine 1 di 2 Sony Vaio PCG-3C2L Motherboard Replacement: passo 17, immagine 2 di 2
    • Unscrew the four 4 mm captive screws from the fan casing using a Phillips #0 screwdriver.
    • Disconnect the black/red/yellow wire connector by gently pulling on the wire.
    • Remove the copper colored fan casing that contains the fan by pulling it off of the bottom of the laptop.
  18. Sony Vaio PCG-3C2L Motherboard Replacement: passo 18, immagine 1 di 1
    • Remove the three 3 mm fan casing screws from the fan casing using a Phillips #0 screwdriver.
  19. Sony Vaio PCG-3C2L Motherboard Replacement: passo 19, immagine 1 di 2 Sony Vaio PCG-3C2L Motherboard Replacement: passo 19, immagine 2 di 2
    • Remove the fan from the fan casing by sliding it out.
  20. Sony Vaio PCG-3C2L Motherboard Replacement, Motherboard: passo 20, immagine 1 di 1
    • Use the Phillips #0 screwdriver to remove the five 3.8 mm screws.
    • Use the Phillips #0 screwdriver to remove the two 3.3 mm screws.
  21. Sony Vaio PCG-3C2L Motherboard Replacement: passo 21, immagine 1 di 3 Sony Vaio PCG-3C2L Motherboard Replacement: passo 21, immagine 2 di 3 Sony Vaio PCG-3C2L Motherboard Replacement: passo 21, immagine 3 di 3
    • Disconnect five wire connectors by gently pulling on the cords to release. They are located around the motherboard.
  22. Sony Vaio PCG-3C2L Motherboard Replacement: passo 22, immagine 1 di 3 Sony Vaio PCG-3C2L Motherboard Replacement: passo 22, immagine 2 di 3 Sony Vaio PCG-3C2L Motherboard Replacement: passo 22, immagine 3 di 3
    • Use the Phillips #0 screwdriver to remove the four 3.8 mm screws.
    • Use the Phillips #0 screwdriver to remove the single 2 mm screw.
    • Remove the MD16 from the motherboard by gently pulling up. The MD16 is the small raised panel which is the same blue as the motherboard. It is attached to a black cord and should remain attached to the black cord.
    • Place the MD16 to the side.
  23. Sony Vaio PCG-3C2L Motherboard Replacement: passo 23, immagine 1 di 2 Sony Vaio PCG-3C2L Motherboard Replacement: passo 23, immagine 2 di 2
    • Remove the small red memory card holder from the laptop by sliding it out.
  24. Sony Vaio PCG-3C2L Motherboard Replacement: passo 24, immagine 1 di 3 Sony Vaio PCG-3C2L Motherboard Replacement: passo 24, immagine 2 di 3 Sony Vaio PCG-3C2L Motherboard Replacement: passo 24, immagine 3 di 3
    • Lift the motherboard up about two inches so you can see underneath it.
    • Underneath the motherboards are more connectors. Disconnect the five wire connectors from the bottom of the motherboard by gently pulling on the wire to release.
  25. Sony Vaio PCG-3C2L Motherboard Replacement: passo 25, immagine 1 di 3 Sony Vaio PCG-3C2L Motherboard Replacement: passo 25, immagine 2 di 3 Sony Vaio PCG-3C2L Motherboard Replacement: passo 25, immagine 3 di 3
    • Once all the wire connectors are disconnected, remove the motherboard from the bottom of the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 26
Tutti i Tempi: 1,536
