Salta al contenuto principale
Sony Vaio PCG-31311L Motherboard Replacement
Cosa ti serve
  1. Sony Vaio PCG-31311L Motherboard Replacement, Keyboard: passo 1, immagine 1 di 2 Sony Vaio PCG-31311L Motherboard Replacement, Keyboard: passo 1, immagine 2 di 2
    • Start with device closed, powered off, and upside down.
    • Locate 3 screws on the bottom plate and unscrew
    • These screws do not detach from the bottom plate.
  2. Sony Vaio PCG-31311L Motherboard Replacement: passo 2, immagine 1 di 2 Sony Vaio PCG-31311L Motherboard Replacement: passo 2, immagine 2 di 2
    • Use a plastic opening tool to pry up on the plate and remove from device.
  3. Sony Vaio PCG-31311L Motherboard Replacement: passo 3, immagine 1 di 1
    • Locate screw labeled "KB" and remove.
  4. Sony Vaio PCG-31311L Motherboard Replacement: passo 4, immagine 1 di 3 Sony Vaio PCG-31311L Motherboard Replacement: passo 4, immagine 2 di 3 Sony Vaio PCG-31311L Motherboard Replacement: passo 4, immagine 3 di 3
    • Use a plastic opening tool tool to pry around the edge of the keyboard.
  5. Sony Vaio PCG-31311L Motherboard Replacement: passo 5, immagine 1 di 3 Sony Vaio PCG-31311L Motherboard Replacement: passo 5, immagine 2 di 3 Sony Vaio PCG-31311L Motherboard Replacement: passo 5, immagine 3 di 3
    • Once detached, tilt the keyboard forward, exposing a blue ribbon cable.
    • Place finger on black tab and pull back. Then, give a gentle tug on the ribbon cable and it will detach.
    • Once the ribbon cable has been detached, lift the keyboard away from the device.
  6. Sony Vaio PCG-31311L Motherboard Replacement, Motherboard: passo 6, immagine 1 di 2 Sony Vaio PCG-31311L Motherboard Replacement, Motherboard: passo 6, immagine 2 di 2
    • Use the plastic opening tool to pull back the ribbon cables attached to the motherboard
    • Use the plastic opening tool to pop up the black tabs and pull the remaining ribbon cables.
  7. Sony Vaio PCG-31311L Motherboard Replacement: passo 7, immagine 1 di 2 Sony Vaio PCG-31311L Motherboard Replacement: passo 7, immagine 2 di 2
    • Locate the LCD ribbon cable
    • Pull up and away from device to detach the LCD ribbon cable.
  8. Sony Vaio PCG-31311L Motherboard Replacement: passo 8, immagine 1 di 3 Sony Vaio PCG-31311L Motherboard Replacement: passo 8, immagine 2 di 3 Sony Vaio PCG-31311L Motherboard Replacement: passo 8, immagine 3 di 3
    • Close and flip over laptop.
    • Locate the WiFi network card.
    • Use the plastic opening tool to pry up the two connectors.
  9. Sony Vaio PCG-31311L Motherboard Replacement: passo 9, immagine 1 di 2 Sony Vaio PCG-31311L Motherboard Replacement: passo 9, immagine 2 di 2
    • Locate the 6 screws on the bottom and remove.
    • Remove the final screw in the center to release the motherboard from the case.
Conclusione
Tyler
Membro da: 08/24/16
45 Reputazione
5 Guide realizzate
USF Tampa, Team 1-1, Lacy Fall 2016 Membro di USF Tampa, Team 1-1, Lacy Fall 2016
USFT-LACY-F16S1G1
5 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,595
