Salta al contenuto principale
Sony Vaio PCG-161L Speakers Replacement
Cosa ti serve
  1. Sony Vaio PCG-161L Speakers Replacement, Keyboard: passo 1, immagine 1 di 1
    • Turn your device upside down and remove the 6 10mm screws attaching the back casing to the device using a phillips head screwdriver.
  2. Sony Vaio PCG-161L Speakers Replacement: passo 2, immagine 1 di 2 Sony Vaio PCG-161L Speakers Replacement: passo 2, immagine 2 di 2
    • Lift up underneath the keyboard using the iFixit opening tool to expose the ribbon wires connecting the keyboard to the motherboard.
  3. Sony Vaio PCG-161L Speakers Replacement: passo 3, immagine 1 di 2 Sony Vaio PCG-161L Speakers Replacement: passo 3, immagine 2 di 2
    • The two ribbon cables connecting the keyboard to the motherboard are held in using zero insertion force (ZIF) connectors.
    • Use a plastic opening tool or your fingernail to flip up the small retaining flaps, then pull the ribbon cables out of their connectors.
  4. Sony Vaio PCG-161L Speakers Replacement, Speakers: passo 4, immagine 1 di 1
    • Remove the three 10 mm screws holding the casing to the top of the motherboard using a Phillips screwdriver.
  5. Sony Vaio PCG-161L Speakers Replacement: passo 5, immagine 1 di 1
    • Remove the 6 mm Phillips #0 screw on the left side of the battery that holds the casing to the device.
  6. Sony Vaio PCG-161L Speakers Replacement: passo 6, immagine 1 di 1
    • Turn the device upside down and remove the 6 mm Phillips #0 screw holding the casing to the device.
  7. Sony Vaio PCG-161L Speakers Replacement: passo 7, immagine 1 di 1
    • Remove the top casing by lifting up on the plastic exposing the two speakers.
  8. Sony Vaio PCG-161L Speakers Replacement: passo 8, immagine 1 di 1
    • Remove the two 4 mm screws attaching the broken speaker to the casing.
    • Each speaker has two 4mm screws holding it to the casing. If you are removing both speakers, remove all four screws.
  9. Sony Vaio PCG-161L Speakers Replacement: passo 9, immagine 1 di 1
    • Disconnect the wire from the board by pulling the wire out of the harness.
    • These harnesses do not have any clips or tabs. Simply pull on the wire and it will come out of the harness.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 296
