Salta al contenuto principale
Sony Vaio PCG-161L Keyboard Replacement
Cosa ti serve
  1. Sony Vaio PCG-161L Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Turn your device upside down and remove the 6 10mm screws attaching the back casing to the device using a phillips head screwdriver.
  2. Sony Vaio PCG-161L Keyboard Replacement: passo 2, immagine 1 di 2 Sony Vaio PCG-161L Keyboard Replacement: passo 2, immagine 2 di 2
    • Lift up underneath the keyboard using the iFixit opening tool to expose the ribbon wires connecting the keyboard to the motherboard.
  3. Sony Vaio PCG-161L Keyboard Replacement: passo 3, immagine 1 di 2 Sony Vaio PCG-161L Keyboard Replacement: passo 3, immagine 2 di 2
    • The two ribbon cables connecting the keyboard to the motherboard are held in using zero insertion force (ZIF) connectors.
    • Use a plastic opening tool or your fingernail to flip up the small retaining flaps, then pull the ribbon cables out of their connectors.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 305
